What is this intake fitting for?
  • Thread starter Thread starter TheBocSez
  • Start date Start date Apr 22, 2006
TheBocSez
652
Converse, TX
Apr 22, 2006
  • Apr 22, 2006
I am Installing a 93 Cobra intake on my 91 LX.
On the lower intake at the passenger side rear is a nipple fitting and I dont know what its for. Best I can figure is its where the coolant line would connect if I was still running an EGR spacer with coolant running through it.
I have also bypassed the heater core by removing the metal heater tube that runs along the intake and relocating the ECT to the front passenger side of the intake where the heater tube used to connect.
On the front drivers side, I have connected the fitting for my aftermarket water temp sensor.
At the drivers side rear is a hole that is plugged.
So, should I plug the hole in the passenger rear also or does it serve some other purpose?
Thanks.
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Apr 22, 2006
  • Apr 22, 2006
Plus itm, you are right it's for coolant that you don't need with the Cobra Intake.
vristang
4,933
101
124
Seattle
Apr 22, 2006
  • Apr 22, 2006
Thanks.
Plug the pass. rear.
Everything else sounds ok.
I take it your ECT threaded right into the front pass. location?
I have wanted to move the heater outlet to the rear, but was concerned about the ECT not threading into the lower intake.
jason
E
  • Sticky
2003 Mustang GT convertible water leak
  • Eightiesrock1980
  • Jul 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 28, 2026
R
Fox Hydroboost conversion/proportional valve
  • RubyRedNotch
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2026
RubyRedNotch
R
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
  • Mindseye007
  • Aug 16, 2026
Mindseye007
