- Dec 19, 2014
- 20
- 2
- 13
Well the charcoal canister and associated components were deff. Removed prior to me owning the car.... I just read a little on this and it's coincidental that I also do have a Raw fuel smell coming from under the hood and I've been trying to find out where it's coming from... now that I know what this is... this may be the issue.
So is it possible to cut and shorten that long tube and re-route it into the vacuum system somewhere without consequence or will I have to reinstall the canister system?
Why not add the canister and associated parts so it functions as intended?
How does this eliminate his fuel smell? FWIW, I have my line dumped the same exact way as the OP and I have zero smell regardless of temperature. I wonder why it's different for some than others.Cap line (rear of car preferred)
Install vented gas cap
edit: I see that the OP is supercharged. Is it possible that the OP has too large of a fuel pump and a lot of heated fuel gets returned to the tank which may cause higher evaporation of fuel and more vapors to vent?
@Assassin 5.0
