what is this??
  • Thread starter Thread starter wazazzle
  • Start date Start date Aug 14, 2005
W
wazazzle
618
In the dumpster behind McDonalds. WA
Aug 14, 2005
  • Aug 14, 2005
im swapping my '89 non airbag dash wiring, which is a real p.i.t.a. was told dash harness i bought ebay was 90or91 so im assuming has airbag. i don't recall my '89 non airbag having this computer onboard. what the hell is it? its the blue thing under the center console area. do i need it connected if i don't have an airbag??
W
wazazzle
618
Aug 14, 2005
  • Aug 14, 2005
anyone know?
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Aug 14, 2005
  • Aug 14, 2005
Leave it hooked up whats the worst it could do?
9
93-331-29psi
157
NE North Carolina
Aug 14, 2005
  • Aug 14, 2005
I just tore the dash out of my 93 this past week. I am in the process of cleaning out the wiring that isn't needed for my use. I will let you know as I have a wiring schematic but haven't made it that far yet.
W
wazazzle
618
Aug 14, 2005
  • Aug 14, 2005
there is that other grn/red & blue/purple wire in front of it that also seems to work with the airbag. i don't wanta a check engine light coming on or anyelse for that matter.... so will it hurt if i leave those disconnected?
9
92SilverLX5.0
Georgetown, Pa - Columbus for school
Aug 14, 2005
  • Aug 14, 2005
I'm fairly sure it's the air bag control module. If you do not want any beeps or lights blinking in the cluster, remove it.
RsStanG1987
569
9
79
Dupont PA
Aug 14, 2005
  • Aug 14, 2005
Leave it in if your not sure youll probbablu F uck something up.
9
92SilverLX5.0
Aug 14, 2005
  • Aug 14, 2005
Everything I've read on the subject suggests that the air bag control module is a blue box located behind the heater controls. So this fits the description. Having never seen it in person is the only reason I'm not saying thats def. it. I would lay 50 down that it is though. If you chose not to remove the module your air bag light will blink code 32. If you do not put an air bag light in, that module will give off 5 sets of 5 beeps every time you start the car and during certain intervals after running the car. ( read very very very annoying)
W
wazazzle
618
Aug 15, 2005
  • Aug 15, 2005
my '89 never came with an airbag option, let alone has any airbag lights... if i reconnect it and it reads i don't have an airbag... or for some reason reads airbag deloyed.. what'll it do... beep like crazy, short somewhere, cause rest dash not to work?
JIffy94
58
Arvada Colorado
Aug 15, 2005
#10
  • Aug 15, 2005
  • #10
Def the airbag module, might have to take mine back out of the trash if its really gonna be that annoying. Darn
powertrax91
598
New York
Aug 15, 2005
#11
  • Aug 15, 2005
  • #11
crazypete
All my crevices are greased.
Oct 22, 2004
930
Arlington, MA
Aug 15, 2005
#12
  • Aug 15, 2005
  • #12
Another vote for the airbag module.
Strip the airbag system out. You'll be surprised at how much wiring is under the dash for that system. I found 2 blue modules I think (long long time ago) and at least 5 pounds of wire crisscrossing the car for that system alone.
keith1991
69
Hawaii
Aug 15, 2005
#13
  • Aug 15, 2005
  • #13
Mine started to make a weird noise, kinda like feedback through speakers when you have a bad ground. Found out it was that airbag module. I removed it. Now my airbag light just stays lit instead of blinking. All I have to do now it remove the light from the dash.
darthcual
985
Arlington, TX
Aug 15, 2005
#14
  • Aug 15, 2005
  • #14
No two ways about it, its the airbag module. I had to unplug mine cuz it kept beeping at me every 30 minutes i guess cuz one of the crash sensors was bad. Finally i just tore it outta there along w/ my crash sensors....hope i dont need it.
9
92SilverLX5.0
Aug 15, 2005
#15
  • Aug 15, 2005
  • #15
What will cause it to beep is if it doesn't have a light in the instrument cluster. Im assuming that since you are swapping a 90 + dash into your car you're putting a 90 + instrument cluster in also. So in short just rip it out, if its out of the car along with all associated wiring then it will not beep and there will be no lights blinking on the cluster.
Jiffy94 and powertrax91 if its out of the car then it won't beep and be annoying.
http://www.veryuseful.com/mustang/tech/airBag/airBag92.html
thats a fairly useful link for learning a little about the system
W
wazazzle
618
Aug 15, 2005
#16
  • Aug 15, 2005
  • #16
well you see i didn't really think that there was going to be a swap prob with my cluster but know i see otherwise. after i clean and transferred the wiring harness to the 89. i couldn't use the 90 dash cause the steering column holder (pastic part) was broken and the color was blue/grey vs. red/grey not . i'm just going to install the 89 dash with the 90 harness and find a 90 speedo with the correct connectors. i noticed last night the connectors where different too. funny how problems always arise. like i said PITA project.
Electrical Dash wiring
  • RileyDymond
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 19, 2026
RileyDymond
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
E
V8 Swap in a 95 - Wiring Help Needed
  • electricityisnotmyfriend
  • May 13, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 21, 2026
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
