What its worth...??
  • Thread starter Thread starter 2vNotch
  • Start date Start date Jan 5, 2012
2vNotch
519
21
29
Rogers, AR
Jan 5, 2012
  • Jan 5, 2012
THIS IS NOT A FOR SALE POSTING
Yest I was cleaning the cars when a plumber that was next door came over to admire them. We talked for awhile about the cars hed had "back in high school" and so on....He mentioned to me he had some "gt40 heads from a lightning"...I wasnt aware lightnings used the gt40s ?? Anyways i figure theyll still be better heads than the stockers on my carbed 86, my question is what are they and what are they worth?? He said theyd need "cleaned" up but idk to what extent....Any help appreciated!
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Jan 5, 2012
  • Jan 5, 2012
Gen 1 Lightnings had the same GT40 heads as the 93 Cobra. They would be a major upgrade over the stock 86 heads, but you very well could have PTV clearance issues with the flat top pistons in the 86. Realistic value is probably $150-300 depending on condition. Bear in mind that they'd probably need a few hundred dollars worth of refurbishing before you install them.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jan 5, 2012
  • Jan 5, 2012
You'll also need to install inserts in the bolt holes to run the stock 7/16 bolts, since Lightning heads will be drilled to accomidate the 351w's larger 1/2" head bolts.
Theyre decent heads, but pretty common now a days. The 1996 and early-97 Ford Explorer 5.0l's had them as well.
What they're worth will depend on your location. Those heads would still fetch about $400 around here. The further south you go, the less expensive they tend to become.
88LX5.Oh
1,442
205
94
Arkansas
Jan 5, 2012
  • Jan 5, 2012
My dad picked up a 302 with 30,000 miles, out of I believe a '99 Explorer (rolled over and sat for years), for $200. He kept the heads, which are the GT40P's, for himself and he gave me the block to use in my car. Gearbanger is correct, further south you go, the less expensive they are.
2vNotch
519
21
29
Rogers, AR
Jan 6, 2012
  • Jan 6, 2012
Thanks!
ID89GT
1,659
18
49
Spokane Valley, WA
Jan 6, 2012
  • Jan 6, 2012
I have a set im sellin to a guy I work with for 175
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
2K
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
Foxtoberfest 2022
  • FastDriver
  • Sep 6, 2022
8K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2022
Ford Moore
F
Progress Thread finishing touches on my stroker build
  • doobismaximus
  • Jul 2, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 1, 2021
nickyb
M
Progress Thread Monkeybutt2000's 89 vert build thread- 408w build in progress
  • Monkeybutt2000
  • Apr 4, 2020
  • 20 21 22
75K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 20, 2026
2Blue2
