What length pushrods? help!
Sirone
63
Hello all! I need help on the correct length pushrods for my new cam swap soon to be done. I have edelbrock performer heads (1.90/1.60) ,TFS1 is the cam I will be going with, 1.7RR's. And stock shortblock. Thanks in advance.
I'd measure them and get it right the first time.
When I swapped my heads I was going to get 6.700 since I had found a couple other guys that used that length but I decided to measure and turns out I needed 6.500 -- 6.700 would have been a bit too long.
Wes
I got my pushrods ordered locally from a performance shop. Summitracing.com would have been my second choice.
I used the CompCams adjustable pushrod to do the checking. Summit carries the Trickflow brand: http://store.summitracing.com/partdetail.asp?part=TFS-9000&autoview=sku
Following CompCams instructions (and the instructions of the engine builder at the shop) I marked the valve stem tip with a sharpie. I setup the rocker like I would normally (zero lash by wiggling rocker then 1/2 turn). Then I spun the engine over a couple times by hand. Took the rocker off and looked at the sweep. You want it centered on the valve.
A longer pushrod puts the sweep closer to the exhaust, a shorter pushrod puts the sweep closer to the intake.
Once I had the sweep was correct I measured it with some dial calipers. I did this twice for both an intake and an exhaust valve just to double check it all.
Wes
jaja, sorry Wes for making you type all of that out.
I have the TFS checker and I know how to measure them and all, but as the article says, it's best to send out the pushrod checker (secured with tape so it won't move) because different companies measure them differently.
So I guess I'm asking you, if you just measured it with the dial calipers and didn't have a problem with the ones you ordered?
I too have seen it said ...
Not everybody uses the same standard of measurement :fuss: :bang: :crazy:
I'd want to talk to their tech peeps before ordering :Word:
Grady
Definitely measure. Most people need a 6.7" pushrod with TFS heads, but I ended up needing a 6.75, and Wes needed 6.5, so there's just too many variables to make a guess. Different brand rocker arms that have the pushrod cups deeper in them, or are of a different design than others, possibly different brand lifters, shaved heads, decked blocks, etc. all come into play.
Get the Hi-tech pushrod checker from Comp cams. I used theirs and had 0 problems. You count the number of turns (line to line), multiply it by .05, and add them to the size of the checker.
Heres mine.
Original Checker length=5.800
11 turns=.550
Grand total=6.350
It was DEAD on.
Grady
Yep, exactly what I did. He told me to just measure it with a long caliper and round to the nearest .050" and I'll be fine.
I wish I would heard of that comp cams hi tech one before I bought this one.:notnice: Now I have to get a long caliper.
So does anyone have the length of pushrods I would need for 1.7 rr's and,eddy heads 1.90/1.60, camshaft really dont care ! Just post your pushrod length with wat cam you have with yor 1.7's.
So I guess what we said didn't matter?
You give up hp, tq, increase wear on rockers, and most importantly, valvetrain stability, etc, when you get the wrong pushrod. Just a heads up. MANY things make up the correct ratio, even the head gasket used!
I will take taht into consideration and will get the correct length pushrods. And just check for correct size. Thanks all.
