What makes the brake pedal sink down??? Help me please!
Black1987Stang
1,422
Jersey Shore
As you can tell from the title when im on the brake the pedal slowly bleeds down to the bottom and ill have to let go , let the pedal come back up and press it and it repeats...Sometimes though it will be nice and hard like a normal brake. Is this the master cylinder or maybe check valve?
Nope no leaky fluid or anything. Its not like a spongy pedal like when theres air in the line, it just sinks down. For the first few seconds its fine then it starts bleeding down and ill have no brake power. I no older Fords are bad for master cylinders so im thinking its that.
You have an internal leak in the master cylinder. Fluid is escaping past the rubber piston seals and returning to the reservoir.
OK so its the master cylinder....Thanks everyone, Ive done a master cylinder on a gmc truck once, all i got to do is fill it with fluid and keep pressing the plunger until fluid runs out of both brake output holes? Can this be done on the car but with the brake lines not connected since i dont have a vise to hold it in? I can get one with or without a reservoir, which one should i get? the one with the reservoir already on it right, so i dont have to swap out my reservoir?. Do i use DOT 5 fluid i forget. I think it says so on the cap though. Do i have to bleed all the brakes also? Thanks alot
Use DOT 4 fluid to be compatible with what you already have.
You can bench bleed the master cylinder on the car without the brake lines connected.
You will have to bleed the system, front & rear when you are finished with bench bleeding. Anytime you disconnect a brake line, you let air in the system.
Master cylinders with the reservoir are generally more expensive than without the reservoir. It is a pull, tug and push operation to swap it from one master cylinder to another.
I AGREE
go ahead and use DOT 5... let us know how that turns out :nice:
jk there, DOT 3 and 4 are compatible, but do not mix at all with DOT 5, it will ruin your brake system. DOT 5 is higher temperature resistant, but collects dust and stuff a lot quicker than 3 or 4, and needs to be changed every few months i believe, if not its a helluv a lot more often than 3 or 4. DOT 5 is mainly for race only cars.
good luck, easy swap but if not done right can have nasty effects
