what next, cams intake what is available for 01 4.6
aeroguy313
9
What is available that will give me good gains without breaking the bank. I am installing c&l plenum & accufab 75 mm tb and was thinking of going with a mass air kit but i have heard they are worthless and would like to spend my money on something worthwhile. I have almost all boltons accept for a cai or mass air. Is cams head and intake my next step? Thanks for any help
do you have pullies and a timing adjuster?
i think that there are 2 more intakes coming out soon that should be cheaper than the Fox Lake P-51.
also you might want to check out VT Engines cams, they might be able to help you.
you could get cams, new valves and springs, ported and polished heads, but all of those would cost a bit of change...you could get a good dyno tune or a Pro-M MAF for a bit less $$ i think.
I think cams and headers are your next step. the maf if a subject I am confused on. I don't whats best or at what point it is a must. I have seen similar setups with headers and cams in the 270+rwhp range. that is good with stock heads. off course after the cams you would need a tune.
[QUOTE='96&'01Stang]Also springs, shocks, struts, sub frame connectors, aluminum driveshaft w/ safety loop, upgrade your brakes, the list goes on...........[/QUOTE]
The upgrade my brakes part is the part I'm waiting on. My brakes will be here next week & I'm driving an hour to get my Speedcal tomorrow & then back home to install it.
