What oil pan gasket on Canton oil pan??
I got a new canton oil pan and in the instructions it told me I should use a 4 pc oil pan gasket to prevent leaks vs. one piece gaskets.... now Im not saying they dont know what they are talking about, its just I prefer to use a 1 piece rubber/steel cored gasket.
Anyone running a 1 piece gasket on a canton pan without leaks???
Anyone with leaks in a canton pan ever??? Let me know I apreciate it. I plan on sealing it this weekend so I apreciate anyones input. THANKS
Need Help Too!
Sorry to resurrect an old post, but I have similar questions.
I was told that a FMS 1-piece would work just fine, but am finding that the rib in the lip of the Canton oil pan will most certainly interfere with the 1-pc gasket.
See picture below. I've done a mock-up with the timing cover in place, and it does not seal.
What do you make of this issue? I am convinced that I will have a leak, if I install it. Thinking I should just go with a 4-piece gasket.
I just want to do it right the first time, and appreciate any advice.
-Harold Jones
1988 Ford Mustang Coupe ( 347W)
well I used the exact same gasket - the Ford Racing 1 piece on my Canton 15-620 pan.No problems and no leaks. I used it after everyone told me not to use the 4 piece and also told by a mustang shop to use it as well. The gasket should be gooved to seat right over top of the rib. I installed a minor amount of silicone at the mains and that's it. No leaks and works flawless!
Help
Cobra912,
Thanks for the reply; yep...heard the exact same thing too.
The thing is that the groove in the FMS gasket is on the top-side and is smooth on the bottom side (where it needs to fit onto that rib in the Canton oil pan).
I don't know if that makes sense, but you can see in my picture there is a nice groove in the gasket on the top-side where it will fit into the timing cover. If almost seems like I should have flipped the gasket over so that the groove would fit on top of that rib in the oil pan, but I know that won't work either.
I am positively stumped. I'm not sure what to think.
I thought about picking up a Fel-pro 4-piece kit at a local parts shop, but don't know if the rubber end piece will be grooved on top, bottom, or both. I figure I will drop the oil pan, install the timing cover, and then sort it out from there.
Thanks for the reply; good to hear that it really should work just fine. I'll take another look at it.
-Harold
Update.
Well, for anyone following my saga...new info below.
I took off the oil-pan, and installed the timing cover and water pump...should have done it first to start with.
I tried to re-install the oil pan with that FMS 1-piece gasket, but it is definitely interfering with the raised-rib shown in my photo above. I had hoped I could get the gasket to compress enough to seal up the oil pan, but I can see daylight between the oilpan, gasket, and engine block near the front of the motor.
I guess I will call Canton Tech Support tomorrow to see what they recommend. I know they sell a 4-piece kit for about $10...just seems lame that a more expensive 1-piece gasket can't/won't work. I just want to do it right the first time and not have any leaks once I get the motor in the car. I had gotten lots of recommendations on that 1-piece gasket...dunno though.
Anyone been down this road before? Any thoughts?
Thx,
Harold
