Well after blowing my tranny last night i decide to go with TKO or new TKO500
Now i need to figure out whatparts i gonna need for T5 to TKO or TKO500 swap
You may already have this answered, but here is a link that helps a bit.
https://lmr.com/products/mustang-tko-swap-guide-79-04
Something they should mention in your notes is that oversized oil pans will require heavy modification in order for the clutch cable and starter to have mounting clearance. I got the Quick Time bell housing for my swap and have been very frustrated by it because they rotated the starter position down about an inch from the factory location so now it sits extremely close to my headers with my stock oil pan and will only fit if I cut out part of my oversized oil pan.
Also, the clutch cable path goes through where an oversized oil pan would be.
I've attached the parts list I got when I purchased my TKO 600 from Modern Driveline.
Paul Coffey over at Modern Driveline helped me a ton on this both in knowing what to buy, but also in installation tips. I'd send him a picture of something and we could get on the phone and work through it.
[email protected]
TKO600RR, Ford Road Race, 2.87, 1.89, 1.28, 1, .82od, 26 spline input, 31 spline output, Mechanical and Analog Electric speedo drive, (Torque rated for 600ft/lbs, 1 year warranty from the date of use)
Bellhousing, QuickTime, SBF, 7:00 opening, Mustang II 157 tooth to T-5/TKO, uses Fox body fork
Clutch lever, 79-93 Mustang, T-5/TKO/93 & earlier Windsor T-56
Crossmember, 94-98 Mustang T-5, TKO's AODE, 4R70W & C6 transmissions (Also fits 96-98 Cobra spec T-45 with Cobra bolt-on mounts)
Mount, Trans, Ford 79-95 All Mustangs, 96-97 GT
Slip Yoke, 31 spline, 1330-16 U-joint, TKO/C6/FMX
Bushing, Steel, for 83-04 Mustang shifter lever MD-320-1043, 2 Req'd 3/8" bolt
