Hey guys, I'm getting ready to order up the final parts that I'll need for my headswap. I've done this once before, but it was for ported E7's so I knew exactly what to get.
I'm going to the stud-mount AFR 165's (58cc) and I need to know which ARP headbolts to get as well as which pushrods to get. I was told I couldn't use the same head bolts that I used last time; apparently I need the ones that will fit a 1/2" hole instead of the stock 7/16." Some kind of washer or sleeve needed perhaps? What's the deal with that?
Also, I'm gonna order up a set of hardened chromemoly pushrods. I need ones that will work with guideplates....what's the best way to go there? I was thinking of going with Comp Cams but I don't see anything that will work with an 86-95 302.
Also, I still need a set of roller rockers and was thinking of going with the Comp Cams Pro Magnums. Are those a good choice or should I go with Harland Sharp? I've heard a lot of people run the CC Pro Mags with good luck. Whatever I get, I need the 3/8" version right?
Thanks guys...
Thanks guys...
