What rack to get??
jstang209
Jun 3, 2004
640
Stockton 209
i called a couple of places and priced some racks bc my is leaking very bad... but every store said there was 3 different ones.. a trw thats runs 149.99, a ford with a (3.0?) 139.99 and a ford with a (2.5?) that runs 99.99.. My car was an original 4 banger so what rack do i need to get??
go with the close ratio steering rack from 5.0resto. i have a 87 exfhp stang and they all came with close ratio racks and it is 10 times better than stock gt or lx steering.
Here's some tips to help do the job...
The two inner tie rod ends are usually what wears out, and at $45 each, it's better to get a replacement rack assembly since they are part of the package. The rack is about $100 + a $40 refundable core charge, which you get back when you return the old rack. Be sure to ask for the GT or high performance rack, it has fewer turns lock to lock than the standard rack.
The flex coupling for the steering shaft needs to be disconnected before you can get the rack out. You should disassemble the coupling by undoing the 2 bolts that hold it together. The lower part of the coupling will then come out with the rack, and can easily be removed.
The tie rod ends can be removed with a tool that looks like a giant "pickle fork", it's less than $8, or some stores will rent/loan one. Remove the cotter pin & nut on the tie end, stick the tool between the rod end and the arm it connects and hammer away. The bigger the hammer, the easier it comes apart.
Remove the two bolts that bolt the rack assembly to the frame and then pull the rack down. Get a catch pan to dump the fluid in when you disconnect the hydraulic lines. I replaced the rack mount bushings with some Energy Suspension urethane ones. When you re-install the rack assembly, put the rear bushings in the rack assembly and lift it into place. Then install the front bushings & washers and tighten down the nuts. Doing it this way makes room for the hydraulic lines without having them bind against the frame.
To change the tie rod ends, do them one at a time. Loosen the jam nut 1/4 turn, then unscrew the tie rod end from the rack. Turn the jam nut back 1/4 turn to return it to its original position. With the tie rod end removed, use a machinist square to measure the distance between the end of the threaded rod and the jam nut. Sit the bottom of the square against the end of the threaded rod, and the end of the blade of the square against the jam nut. Duplicate the measurement on the new rack and then install the tie rod end and tighten the jam nut. Then do the other side: the front end will need aligning, but the toe in will be close enough to the setting of the original rack to drive.
Buy several extra quarts of fluid to run through the system to flush it when you change the rack. The car needs to be up on jackstands for the next step. Fill the pump up, start the car, and turn the wheels lock to lock to bleed the air out. Then stop the engine, disconnect the low pressure hose (the one that is secured with a hose clamp) and drain the pump. Re-connect, refill and do it several more times or until the fluid looks clear and not burnt or black.
I have replaced a few racks on my cars and here is what I have found. When you buy a rebuilt rack at the parts store, even if you specifically ask for whatever year rack for a GT, the parts guy will ask if you want the TRW rack, Ford rack with one piece bushings, Ford rack with 2 piece bushings, and if car is equiped with performance suspension or not. You will get the same questions when asking for a 4cyl rack (but why would you do that). Answer wrong and you end up with the 4cyl rack. It will bolt right in place of the V8 rack but will have the slower ratio. I have yet to have a car that was equipped with a TRW rack so I dont know what application they are used in but I suspect maybe SVO's. All my racks have had the Ford logo stamped into the case near the driver side bushing if memory serves. All of my cars also use the 2 piece bushings so again I dont know what application used the one piece bushings. I buy alot of auto parts so my parts guy was happy to order all 4 racks so that I could compare and twist em around to compare lock to lock turns. The one listed for performance suspension turned out to be the one for a 5.0 car but it only comes with the one piece bushings. Other suppliers may have it with the other bushings but this particular rebuilder didnt offer them that way. My parts guy let my swap them with the two piece bushings from one of the other boxes though. When I replaced the rack in my 86, the PS line connection at the rack was a different style than any of the later racks I have done. I have also found that there are at least 2 styles of fittings at the pump. The fitting is interchangeable from pump to pump and doesnt seem to be based on if its a 4cyl or V8 pump because I used a V8 line when I changed to the V8 rack on one of my previously 4cyl cars and the fitting on the V8 pump was different but I was able to take the correct fitting from an old 4cyl pump I have lying around. I also compared the 4cyl and V8 line at the parts store and all the fittings were the same so I am assuming that any fitting variations must be year dependant.
Anyhow, my suggestion would be to go with the V8 rack. I have done it on my 4cyl notch as well as my 92LX that was an original 4cyl car. Easy upgrade since you have to change it anyway. And I always just go ahead and replace the outer tie rods while Im at it. I install them while the rack is out on the ground and measure the old one to get the alignment close till I can get it to the alignment shop.
