what setup for hplv gun?
95stocker
236
Rochester
Will a 33 gallon tank with a 6hp single stage pump be enough for a hplv gun to spray my car? Need lots of help on this one, gonna start on junk fenders and work my way up to painting my scraped up car.
The size of the tip will correspond to the amount of solids you are spraying.
For example, epoxy primer requires larger than basecoat, and basecoat larger than clearcoat. Clearcoats are around a 1.5 usually, and basecoats are normally 1.6-1.7. Check the technical bulletin for the paint you will be using. They also give air pressure at the cap, time to dry, recoat, tape etc.
joe.
