what SHOULD i be getting out of this guys?
Modular2v
3,222
23
99
oklahoma
fully forged 331 stroker, afr185 heads, Weiand stealth intake,TFS2 cam, holley 750dp, full manual valvebody AOD with a 2800stall, 4.10s, 31spline spool with moser axels on Et streets.....im going to be very dissappointed if it doesnt hit mid 12s!!!
My car (1994 gt) with 331, Vic Jr heads, Performer RPM intake, Crane 20 30 (same as e cam) 30 lb injectors, stock t5, all stock suspension and 3.73's on BFG drag radials went 12.70 at 2600 ft above sea level with a 1.8 60 ft. Mid 12's should be no problem...Depending on your driving ability I say 11.90-12.50
wait...you're going to run a spool on the street? :shrug:
or do you have what's in the sig...
If it's put togther right, that car should be 11.50's, and/or in the 120's in mph (depending on traction.
But i've seen better parts go slower, so who knows.
The aod isn't gonna show the best dyno #'s I'll say 325-330rwhp. You will have 11's all day. Is that enough stall? (I don't know much about them) You can't splurge for a custom cam instead of guessing? You will need to upgrade your valve springs regardless.
2800 should be enough for the STG 2 cam, it advertises 2500-6000rpm range...maybe a little more would be better, but the torque output of the engine will make the stall speed vary, if it's got good torq, it can make the stall speed higher
