I have a good amount of parts for redoing both my front and rear suspension right now. All I wanted to do was get some suggestions on maybe some little things that could be done at the same time while I'm in there. For example, I purchased spring isolators for both the front and back for the new springs I bought. I'll list what I have so far, and then anything else you guys suggest would be greatly appreciated. I want to get as many things done at once as I can.
So far I have purchased:
BBK Upper and Lower Control Arms
KYB GR-2 Shocks and Struts
Suspension Techniques Springs
Energy Suspension Polyurethane Spring Isolators
I also have a Ford Racing aluminum driveshaft and a Walbro 255lph High Pressure HI-Flo Fuel Pump that I want to install on a different day. So while I'm installing all these things, is there anything else I should/could do at the same time? I think I might replace the U-Joints when I do the driveshaft, but I havn't even taken a look at them yet. Thanks guys
*My current goal is be around the 450hp range after I add a turbo or two, but the car will only really be used for daily driving, not too much 1/4 mile track action. Incase that helps anyone.
