what size cam?
Modular2v
3,222
23
99
oklahoma
here is the setup.... 331 stroker with dnd pro hawk 210 heads, port matched weiand stealth,750double pumper, g force t5, 3.73s and a 150 shot. Can anyone give me and idea on what cam i should get?
90mustangGT said:
Ill also add ww.cammotion.com ,they did our cams.
What kinda cam you looking for Hyd. roller?Mech. roller?
BTW,your "nitrous" and "normal" cams will be differant in specs.
So let them know what shot you plan on spraying most of the time (you say 150,but I bet you'll have the 180/210hp jets in in no time :D )
hyd roller,and you are probably right about the jetting and then of course i will be praying to the block gods haha
Modular2v said:
what are the specs on this cam?
Comp Cams XE282HR
0.50 232 IN. 240 EX. lift 1.6 .565 IN. 574 EX. centerlobe 112º
RPM range 2600 to 6500
PART #35-522-8
is not for a daily driver.....
or XFI stroker cam 236HR-14 @.050 236/248 lift .579
PART #35-775-8
second option but i like more the first one....
none of both i recomend for a daily driver a little rough iddle.....
