what size injectors
  • Thread starter Thread starter 306man
  • Start date Start date Sep 22, 2007
306man
17
denver,CO
Sep 22, 2007
  • Sep 22, 2007
I have a built 306 9:1 compression... f303 cam .512 lift and edelbrock 190 160 heads... everything else is stock for the top end.... any suggestions....
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Sep 22, 2007
  • Sep 22, 2007
24's or 30's and matching MAF.
306man
17
denver,CO
Sep 22, 2007
  • Sep 22, 2007
ok i will go with the 24s. its ok that i have stock fuel pump???
ttop88
42
indiana
Sep 22, 2007
  • Sep 22, 2007
If you have stock intake and t-body 19s will work. You need a intake b4 you need injectors
306man
17
denver,CO
Sep 22, 2007
  • Sep 22, 2007
motor runs i have stock intake on the car...
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Sep 22, 2007
  • Sep 22, 2007
My 302 is similar and when it was in my '89GT I ran it on 19s and raised the fuel pressure. It runs a lot harder with the better intake that's on it now, though(not EFI anymore, but it really liked the extra air regardless).
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Sep 22, 2007
  • Sep 22, 2007
stock 19s would work just fine for that combo
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 22, 2007
  • Sep 22, 2007
I would have to say the same stay with the 19's. I have GT40p's poted polished all bolt ons portd polished cobra intake. The car dyno'd 301/338 at the wheels with c&l 76 MM and stock 19's. The guy before me putt 24's and matching tube and it has a hiddious rich/fuel smell. peace
john
CRASH7772
401
NH
Sep 22, 2007
  • Sep 22, 2007
Stock fuel pump will run out before injectors IMO. Both are good for around 300fwhp.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Sep 23, 2007
#10
  • Sep 23, 2007
  • #10
i'd upgrade the fuel pump regardless. stock is like 50 lph, and i'd get at least a 190, a 190 will support pretty much anything, if you get real radical get a 255. on these cars you cant get to big of a pump, if your pump flows a load of fuel that the engine doesnt need it just returns it to the tank, if you have a 255 it just returns ALOT of fuel. no problems.
factory 19lbers go a long way, too many times do i see a pretty much stock mustang, maybe a CAI or headers you know. that has 24s or even bigger on them, NOT NEEDED!
personally if a person is going to make enough power to require larger injectors i would invest in a tune or tweecer or similar along with it. that way you can go into the EEC and tell it what injectors you have and set the flow to run perfect with the application.
i am not of a fan of the "calibrated" sensors and such. the modified sensors and sample tubes. once you upgrade past stock injectors the "calibrated" stuff will send out modified voltages (pro-m etc) or take less of sample of air ( C&L tubes) and the EEC will read this as less air, in turn it will dump in less fuel, BUT it will be the correct amount of fuel you need or pretty close. for ex. say you have an injector flowing exactly 2x the rate of the factory, the sensor would send HALF of the return signal back to the EEC, so the EEC only shoots out half the fuel, but since your injectors flow twice as much, your getting the same fuel as if you were running factory injectors with the MAF sending the full return signal.
sending out these modified signals back to the EEC isnt ideal. the EEC also uses the MAF signal to determine your load% when you run the engine, the MAF sending less signal back to the EEC is telling it "hey less air is coming in" so the EEC thinks its not running at as much of a load as it actually is. so for example you may be running only 70% load when your actually 100%, since the EEC thinks your at 70% it will utilize the spark advance/retard tables and such for a 70% rather than the 100% that you are ACTUALLY at. so you could have power left out on the table.
the aftermarket "calibrated" stuff is made to fool the factory computer, without any computer tuning of any sort, the EEC thinks its running 19lb injectors.
the IDEAL way to do it is get a tune or tweecer etc and go in and tell the EEC what injectors your running, so it knows, and you can mess with fuel tables for idle only, so you can get an awesome idle with HUGE injectors, and get the car to start alot easier.
people running LARGE injectors with no tune, a good amount of them seem to have a hard time starting the car and a horrid idle. rich and loading up, no good at all. with a tune you could make a bone stock mustang idle like factory and run good with huge ass injectors ( pointless but you could do it)
i'm no expert but this is what i have gathered on the MAF related stuff
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 23, 2007
#11
  • Sep 23, 2007
  • #11
Stock fuel pump is either 88 or 95lph
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Sep 24, 2007
#12
  • Sep 24, 2007
  • #12
i have a used trick flow street heat with a 70mm throttle body and spacer for sale, the stock intake is really gonna hurt power on that motor. PM me if your interested.
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
