S stangg01 New Member Mar 17, 2006 129 0 0 Jun 3, 2007 #1 Jun 3, 2007 #1 I'm concidering new sway bars for my 01 mustang gt. So far my search has yielded the following results for the sway bars: front / rear gt 26.5mm solid / 23mm solid bullitt 28mm tubular / 21mm tubular Any help will be appreciated
S stangg01 New Member Mar 17, 2006 129 0 0 Jun 3, 2007 #2 Jun 3, 2007 #2 I've lowered the car about 1.5" with the Eibach-Pro kit, replaced the stock struts and shocks, and put 275x40x17x9 on all corners. I'm now thinking of improving the handling.
S stangg01 New Member Mar 17, 2006 129 0 0 Jun 3, 2007 #3 Jun 3, 2007 #3 I think I just found it on the SVT forum 29mm front 24mm rear (IRS) Thanks anyhow
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,376 18,123 224 Massachusetts Jun 3, 2007 #4 Jun 3, 2007 #4 A bigger sway bar won't necessarily make it handle better. A thicker bar will make the car more prone to pushing in the corners.
EPIK Member Jul 3, 2004 796 1 16 LEFT COAST Jun 3, 2007 #5 Jun 3, 2007 #5 If I remember correctly, the Cobra front swaybar is the same as a GT. its just the Cobra rear thats bigger. I could be wrong though?
S san~man O-G Founding Member Nov 29, 1999 8,546 3 78 A little grass shack on a big lava rock Jun 3, 2007 #6 Jun 3, 2007 #6 Sway bars are one of the last things you need to upgrade, suspension wise. What have you done so far with your current setup? (nothing listed in your sig)
S stangg01 New Member Mar 17, 2006 129 0 0 Jun 3, 2007 #7 Jun 3, 2007 #7 My mods are as stated above. Suspension only.
S san~man O-G Founding Member Nov 29, 1999 8,546 3 78 A little grass shack on a big lava rock Jun 3, 2007 #8 Jun 3, 2007 #8 You'd be better off installing a good set of LCA's over a sway bar.
