I paid 259 for my 65mm accufab,I think 169 for my 75mm bullet pro-m,and Im buying a t-moss ported lower intake for 130.If you have stock heads,you might wanna do the same.JMO
Do you plan on adding bigger injectors as well or get something calibrated for 19's if you choose Pro Flow? That might be the question I would ask yourself so you dont spend money on the same item twice at 2 different times.
i dont plan on gettting injectors anytime soon. maybe i should wait tell i get them? what about a new upper and lower manifold? like Trick Flow Track Heat?
Cobra's a good intake,again if you go with an after market intake,track heat,,,,,,,,,,,youd be better off doing something with your heads first.JMO,,some guys have good luck,and like the performance they get with them. In a perfect world the best thing to do is a HIC swap at one time But being you already have the cam,look into what heads and intake would best suit your cam!! Then your rockin
