Do you guys use. I have a 351 w/ trick flow intake and heads. car has a BBK 75mm and was wondering if I should go bigger?
and what MAF do you guys run?
My 351 is now a 383. I use a 90mm Throttle Body and a SCT 90mm MAF. If using forced induction i hear you can get away with smaller. But i went from a 75mm to a 90mm and the biggest difference is throttle response. It also depends on the heads and what your power goals are.
Chris
I have a spare 75mm Trickflow R upper
That's terrible, you should give it to me![]()
+1
if you donate it to my school, it is a tax write-off![]()
Okay so i will stick with the 75mm for now.
So What MAF sensors do you guys use? The PRO-M was the hot ticket 15 years ago when i use to race.
If the intake opening is only 75mm and you put on the 90mm, you will still flow only 75mm.
How exactly are you going to put a 90mm TB on a 75mm opening?How exactly are you going to put a 90mm TB on a 75mm opening?
It still bolts up, no matter the diameter.
Just have the intake opening ported to a 90mm.Do you guys use. I have a 351 w/ trick flow intake and heads. car has a BBK 75mm and was wondering if I should go bigger?
and what MAF do you guys run?![]()
