If the look is all you're after, then put on the size you want - watch out for tires coming in contact with the metal bits. However, if you're actually looking for performance increase, you may come up with a different answer. A certain width wheel is needed to take advantage of wider tires. It's necessary to spread the tire and keep all the tread flat on the road surface. Mounting a 255 tire on a 7" or 7.5" wheel is possible - but it's doubtful that you're getting signficantly better performance because the wheel is too narrow to properly support that tire. A good rule of thumb is to keep the section width of the tire (the 225 or 255 number) no more than 2" wider than the wheel width. The section number is in millimeters, so divide it by 25.4 to convert to inches. You can see that a 255 tire's section width is a little over 10" -- subtract 2" - you need at least an 8" wide wheel to support that tire; 8.5" or 9" would be better. Additionally, the 255 tire is heavier than the 225; it takes more power to rotate a heavier wheel/tire. Once traction has been achieved - the car will accelerate and stop slightly less effectively with the heavier wheel/tire package.
If performance is what you're after - focus on getting a really sticky 225 tire for your stock rims. The racers out there can tell you what works. If you want to use the bigger tire, get a wider wheel to go with it, and keep the package as light as you can for best performance. If the look of a bigger tire on your stock rim is what you're after - slap the 255's on there. Just know that they may actually hurt the car's overall performance.
