i like the vortech sq trim because its not very loud, it gives the car a sleeper quality
I am opposite of you. I want it to be loud that's why I want the Vortech V1.![]()
No question the KB is a quality kit and the most expensive. So factually what is it about Prochargers that make them substandard? And why are their intercoolers inefficient?
i like the fact that procharger yuo dont have to mess with the oil...
how much did your supercharger cost.. lol
so final verdict
a) procharger
b) votext..
and why
thanks
Votech (Mongoose Kit) LINK
-Awsomew kit that makes good power
-Can upgrade to T-Trim for cheap down the road
-Easy to tune if time comes you want a custom tune
-Great Customer Support
i alrerady have a custom tune on my car by PSI motorsports here in texas...
so from what i hear the vortex is a lil better.. PSI is gonna install it for me
and whats the diference from the trims or what not...
cause i want the best
thanks for the help guys!
I have a P1SC-2 Procharger on my car with the 3 row intercooler. 387 rwhp with no issues. I have had no issues, tuning or otherwise, other than the idle issue after the initial installation. It turned out the idle issue was the Mac T/B, not the tune or the Procharger. Complaints about the tune should be looked at in terms of who is supplying the tune. For instance, when using the Predator, it requires a custom tune on all blower applications. Those tunes are usually accessed by your dyno tuner. To blame ATI for a poor tune or tuning issues is ludicrous. Oil leaks can only come from 2 areas and usually occur when someone tries to reclock the head unit after the unit has been run. It's because the o-rings stick from the heat of being run previously and then are damaged when reclocking the head. The other oil leak issue is at the drain plug and the o-ring must be changed after each oil change because the o-ring crystalizes from the heat. The proper o-ring size is critical here as well. If you know what your doing and you understand how ATI engineers their superchargers, there aren't any issues. I have heard of a few internal misters failing but that is rare. The problem is most people don't know what they are doing. I installed mine myself. I have had the head unit apart and I have reclocked the head unit on Prochargers. Let's face it, testimonials are only as good as the people using them. And most of those people don't install their own units, nor do they get involved with the operational functions of the unit. How many of these people have actually dissassembled a head unit? Or understand in theory its design to function operation? ATI has other blowers for racing capabilities besides the P1 and D1 units. And for the record, ATI has the fastest supercharger ET in the world and is the world record holder. Because you raced and beat someone with a Procharger proves nothing. There are over 4 different pulley sizes available for different boost applications and the amount of power adding choices of associated bolt-ons is damn near limitless. ATI measures its ITs before the intercooler, so stating that as your reason for an inefficient intercooler setup would be inaccurate. When Dynoing with an intercooler, all you have is the portable fans and that is a long ways from an actual simulation of intercooler efficiency. In fact, the fans are only good for 2 or 3 pulls before the temps rise on any intercooler. The fans cannot push enough air like driving at 65 mph would. I think that the KB is probably the best all around but there is nothing wrong with Vortech and others. They all serve their purposes. But to bash ATI from rumors from others who don't know what they're doing is an unfair characterization of a fine piece of equipment. Just my .02
I know for a fact that there are only 2 leak zones on the P1 and D1 blowers. I also know why they leak. I was just trying to clairify the oil leak problem falacy. I am also aware the ATI has had some quality control issues from time to time with their assemblers. With that said, I haven't heard any new units leaking, but if you have, then so be it.
What you actually stated was that there have had tuning problems with the Procharger. I only stated that the tuning problems have nothing to do with the Procharger.
My intercooler statements are not an excuse, but are a fact. And I stated intercoolers in general when using dyno result pulls. I was not specific to a particular intercooler. What you stated was that ATI's intercoolers were not as efficient as the others and all I was pointing out was that a dyno cannot measure the true efficiency of an intercooler. So, then my question is, where did you get your intercooler efficiency numbers from? My other point was those numbers will vary depending on where your ITs are measured from and I used as an example the ATI's are measured before the intercooler. So maybe you could direct me to that internet information?
It is also a fact that most blower owners know very little about them and most pay someone to install them. The result is a lot of information that is regurgitated about superchargers is jaded info at best. You and I probaly know a little more than the average shmo, but ATI does build a quality unit. And you know that I could dig up negative info on all the other blowers on the market. When I did my research before purchasing my P1SC, I found all kinds of negative crap about all the blowers on the market. All I could do was sift thru all of this crap and try and make a educated decision. I bought a used unit and ended up taking it all apart so I could learn about it...and then had ATI rebuild it after I was thru examining it. I'm not an expert by any means, but I now know enough to be dangerous...lol
