What suspension set up do you have to run 1.6-1.8 60' on DR's?
My old stang 88' Gt stock motor on 175hp Top Gun system with 3000stall , 3.73's and a set of MT sportsman pros on some ten-hole rims. I went 13.0's and a occasional 12.9 on a stock suspension and the front sway-bar removed. I would normally get 1.8 to 1.7 short-times. I used a full-throtle switch and sprayed off the line.
Hope this helps...
I've gone 1.854 on the stuff in my sig + PST stock replacement springs, Hotchkis U/L CA's, and KYB Gas-A-Just struts/shocks. (Front swaybar still attatched). This was on Hoosier Quick Time Pro's @ 12psi. It was my first time at the track with the new parts so I'm still experimenting with tire pressure and launch RPM. I also picked up an airbag for the passenger side over the winter so that will add to the mix now :bang:
