It's better to look at your target temp than what stat you'll use. Some guys with a 192/195 stat run at 200* and some with a 180* stat run at 200*. If the system is lacking, the cooler stat can act as a band-aid. 190-210*F is optimal coolant temps.
Whatever you choose, I'd highly recommend using a balanced t-stat.
