So i finally get my car running last week. I took it for a test drive and the clutch wasnt grabbing enough. So i went to adjust it and my firewall clutch adjuster wouldnt work. So i figured ill take it to the garage up the street. I just did the rack when i did the engine and went to put steering fluid in. I turned the wheel and the rack went pop and i had steering fluid all over my freshly redone engine. So i get it to the garage had them do some stuff because im sick of it already. The guy worked magic with my car and everything was how i wanted it. Now for the bad part i went to show the car to a friend and the car drove fine. I go to leave his garage and i couldnt get the car into reverse for the life of me it was really hard. I pushed my car so i can pull out in first and every gear was hard to get into except 3 & 4. Is my transmission shot or does it need to be sycronized. And is there a place anywhere on the car to add tranny fluid? Also i once had a blazer that had the same problem we replaced the slave cylinder and it was fine could that be the problem if my car has one? If i diddnt dump so much into the engine i would sell the car.
