  • 1994 - 1995 Specific Tech
what the!!!!??????
  • Thread starter Thread starter vladasap
  • Start date Start date Jan 6, 2008
1 of 2 Next Last
vladasap
294
nyc, ny
Jan 6, 2008
  • Jan 6, 2008
a friend of mine owns a 95 cobra with a jlt CAI and a bigger mass air
i used to race him before my HCI swap and he was the perfect match for my car- we were ALWAYS dead even - he cant pull an inch on me n i cant pull an inch on him
well, i did my ported cobra lower and stock upper, ported gt40's and a tfs stage 1...
WE are still dead even - we did 30, 40, 50 n 60mph runs a bunch of times and we are still neck to neck exactly like we were before i did all the work (the only thing i know is wrong is that i have a header leak - thats it!) no vacuum leaks, all bolts are tight, all the supporting mods have been done like the mass air, injectors, fuel pump, afpr n such
why didnt my car gain ANY power ????????
could it be that i need a chip tune n what exactly is it that a chip would do to allow the car make the power that it should ?????
PLEASE HELP $900 spent for 0 gains = not good = im angry
Y
y22kc
  • Jan 6, 2008
What were your mods before the H/C/I install?
vladasap
294
nyc, ny
Jan 6, 2008
  • Jan 6, 2008
before the HCI i had 4.10s, 24# injectors, 76mm C&L, shorty headers, x-pipe, short shifter and an msd dizee/blaster/9mm wires and an aluminum d/s
i highly doubt thats the 24#'s n the C&L are not sufficient - im almost certain that they are ---- am i wrong?
drakesdad
961
Oregon OHIO
Jan 6, 2008
  • Jan 6, 2008
I run 24's.....MHO is that is not your problem......I would look into getting a tune....you should have noticed a gain.....if your sure everything is together.....dizzy, timing, no vac leaks,......there should have been some gain.....
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jan 6, 2008
  • Jan 6, 2008
Could be so many different things
Could be several little things
Header leaks and small stuff like that certainly won't help so I'd get
all those issues knocked out and done with.
How does it run around town if you are just cruising around ... NOT WOT
I mean ... does it run smooth ... no misses or anything like that
How much spark value at the dizzy are you running
Are you sure you got the correct cal tube for that C&L
Grady
R
Rock777
195
Troy, IL
Jan 6, 2008
  • Jan 6, 2008
With the H/C/I, your power will move up in the powerband. What rpms are you shifting at? The extra ~1000rpms is where your peak horsepower falls, it will make quite a difference by shifting higher, probably around 6000ish.
WHITE94COBRA
816
HUNTINGTON BEACH
Jan 6, 2008
  • Jan 6, 2008
Guy's he has no tune, his stock computer is still reading and calibrating for #19 inj, and mass air. It's alllll in the tune. It should run very rough sputter and stall. nevermind my post I just re read your post. You still need a tune though.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Jan 6, 2008
  • Jan 6, 2008
swap the 19's back in, and see what happens, you dont even need 24's with that h/c/i ive ran a very similar combo, and it ran balls out!! very quick car..
Black95GTS
1,644
Marlborough, MA
Jan 6, 2008
  • Jan 6, 2008
Definitely work on the header leak, you would be surprised, if you're exhaust doesn't exhale properly your engine won't inhale properly. An engine is just an air pump.
Then you need to get a tune. Further more, you need the 24s in there as well.
Adam
earleys94gt
1,223
Ashley, Ohio
Jan 6, 2008
#10
  • Jan 6, 2008
  • #10
Get it tuned and go from there.
vladasap
294
nyc, ny
Jan 7, 2008
#11
  • Jan 7, 2008
  • #11
well, i bought myself a timing light today and turned the dizzee a few n set the timing at 15
seems like that did change things a bit - the car simply feel faster but i havent had a chance to give her a go with my buddy's cobra to compare n see actual results
as for the tune i decided that i do have to do that since theres almost nothing stock but the tranny and the bottom end so.....
now about the tuning thing - theres a guy who'll adjust my timing and fuel pressure on a dyno for $150
OR
do i have to go all out and get chip burnt for $600?
ahhh tuners! so much $$$
Black95GTS
1,644
Marlborough, MA
Jan 7, 2008
#12
  • Jan 7, 2008
  • #12
I wouldn't just get the timing and FP adjusted. That is an old mentality that doesn't belong in computer controlled cars in my opinion.
Get the chip burnt. You'll get much more HP that way as well. You'll be leaving a ton on the table by using just the timing and fuel pressure.
Adam
ProKiller
3,064
15
78
PA
Jan 7, 2008
#13
  • Jan 7, 2008
  • #13
you've already spent $900 and you haven't gained anything. spend another $600 and get the horsepower you should have gotten with the 900.
vladasap
294
nyc, ny
Jan 7, 2008
#14
  • Jan 7, 2008
  • #14
you convinced me
imma have to wait a week or two to get that cash together n then imma check in with you guys n let you know how it goes
*****btw im completely clueless when it comes to tuning n such so please let me know what i have to look out for - any do's n don't's when it comes these chips or should i tell me tuner what to do n what not to??????
also - we do have that tip n retard when we engage the clutch, now i've heard of ppl who tune the car not to do that but i guess ford did that as a safety to keep the tranny safe and whatnot so i was wondering if that be a good idea to do that
vladasap
294
nyc, ny
Jan 7, 2008
#15
  • Jan 7, 2008
  • #15
and ROCK777 - i deff did notice that the power band moved up a whole lot
the cam only starts moving the car around 4,000-6,200 while before it used to move at 3,000-5,300
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jan 7, 2008
#16
  • Jan 7, 2008
  • #16
OR
The first thing I would have wanted to know is ..........
What was the dizzy on BEFORE you made the change
I mean ... if it was low like 6 or 8 ...
that is where your missing power was ... or at least ... some of it
I been following this thread and I still have a hard time believing you found
no power gain at WOT conditions with the h/c/i upgrade
I know I know ... that project may have caused some drivability issues
but
If things are even half way close ...
You should have experienced a NOTICEABLE gain in power at WOT
Yes ... a tune will certainly help you after the h/c/i project
but
I just gotta think something else is going on here
A q or two about those heads
Are you certain about their condition or status of good standing
I know they were ported but ... was it done correctly
Are the valves sealing correctly
Are the valves adjusted correctly
Have you got the correct length of push rods
That C&L maf and cal tube
Same stuff you were running before the project
and
Was it running correctly before you did the project
Are you still running the OEM fuel pump
I'll go out on a limb and say you got something like that going on
You just don't upgrade h/c/i without making more power :Word:
Something fishy is going on here
Grady
maximos
188
Columbus, OH
Jan 7, 2008
#17
  • Jan 7, 2008
  • #17
the cam only starts moving the car around 4 said:
Was the cam installed straight up? You could lower your powerband if you advance the cam timing a few degrees.
Don't confuse cam timing with ignition timing either. Ignition timing can be adjusted through your tune. Cam timing is a physical trait of the cam, it's the way the cam itself is oriented when installed.
vladasap
294
nyc, ny
Jan 8, 2008
#18
  • Jan 8, 2008
  • #18
ill be honest i didnt check where the timing was at before ...which i hate myself for as i only realized that i didnt check it after i was all done --> newbie/idiot mistake
the fuel pump is a 255 walbro so im sure thats not it- well ill tell you honestly it feels like it pulls really solid now after i advanced the timing but surely enough my lady gives me a new problem
after i advanced the timing (15*) the car has very weird hanging idle - at idle its great but the moment i start moving n im about shift a gear the rpms RISE on their on, hang for a few before dropping and another thing thats really weird n is really annoying me is that if the car is in motion - no matter how fast or how slow - the rpms wont drop below 2000 in NEUTRAL - it just sits there as im rolling down a hill or something in neutral **i tried by just having a friend roll it down a hill while im in the car n its NOT IN A GEAR - the car was idling great (900 or so) n then the moment it started moving over a 2,3 mph the the rpms just jumped to 2000 n stayed there until i came to a full stop
vacuum leak maybe????? i just cant think of a thing that would cause the rpms not to drop below 2000 if the car is in motion
please help me resolve that
and maximos im aware of that but thanks either way, n i gotta tell you, i kinda like the power all the way up there =)
vladasap
294
nyc, ny
Jan 8, 2008
#19
  • Jan 8, 2008
  • #19
I JUST WANT TO GIVE A BIG THANKS TO EVERYONE ON STANGNET FOR HELPING ME OUT WITH ALL THESE QUESTIONS N CONCERNS I'VE BEEN HAVING
you guys really helped me so much with all your input as theres no way i'd be able to figure it all out nor would i have so much money to have a mechanic look at it all
:SNSign:
ps- dont forget the post above please =)
R
Rock777
195
Troy, IL
Jan 8, 2008
#20
  • Jan 8, 2008
  • #20
Mine hangs pretty bad while moving also. It also hangs in between shifts, not quite 2000, but still around 1600-1700, for a few seconds after stopping. I am hoping a tune in the near future will get rid of this. Resetting my idle like talked about on here helps a little. If you haven't seen any of these threads yet, search for "resetting idle" or "hanging idle", might help you some. Good Luck.
1 of 2 Next Last
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
A
need help and advise
  • amps1956
  • Oct 14, 2025
  • Other Auto Tech
Other Auto Tech Oct 21, 2025
Mcmahst
