sliver02GT said:
ok, my timing is running 25 at wot right now, what should i be at w/ a nx 100 shot(wet kit), i will be installing this kit in 2 weeks and am wondering what timing i need to be running....
also what plugs are you guys using w/ 100 shot? and are you using race gas or like 104 or 103 octane?
Is your 100 shot wet or dry? My answer depends partially on what kit you are using. If it is an NX Wet kit, I would say probably 2 degrees retard. That would put your advance at 8 degrees. Stock is 10. If it is a dry kit, 1 degree should be enough as most of these put down about 80 rwhp. If you get detonation, then retard some more.
The text book, safe answer I believe is 1 degree for every 50 shot added.
Plugs? Use copper and gap at 35. Smaller gap prevents the juice from blowing out the spark. As far as heat range, you could use one step colder or even two steps colder. If you live in a winter climate, you may have some problems starting the car if the plugs are two heat range colder. Problem with nitrous and choosing plugs is that you need a colder plug for the juice, but not when running n/a. If the plugs are too cold, they will foul. One step colder should not pose any more problems then perhaps a little rough start when cold.
With plugs, the text book answer is one heat range for every 50 shot.
I have a 100 shot dry, retard timing by one, and use one heat range colder. Autolite 103 is my plug of choice.
And of course, be sure to read them especially when starting out and increasing the juice.
