What To Do About My Idiot Mistake???
I just replaced the rear brake pads and my dumb@$$ left the emergency brake engaged. :damnit:
I just finished puting back everything and than i noticed it.
I took back everything off. question- where is the piston at when there's no pressure from the brakes?
Do i have to push back the piston so far or what?
What should i do? My car has 4-wheel disc brakes factory w/abs.
thanks, Jason
If your piston is all the way out and the pads are together, take the outer pad off, and leave the one against the piston on, and use a C-clamp to push it back. Tightened it very slowly!put your pads back on and you should be fine.
For the rear, you have to use the piston tool to turn it. I didn't think you could use a c clamp for the rear brakes. I had to turn and turn and turn and turn to get the piston down.
NO the pistons on these cars will not go back in with a C-clamp.. the rears on a mustang are not the same type as a explorer or exped. they use mini drum brakes inside the rotor hat. where our cars use the regular disc pads as a e brake.
to get the piston back in so you can get the caliper over the rotors you have too.
1. have the proper tool too turn the piston ( our cars have a twist in piston in the rear) just like a screw or bolt you turn it and it goes back in..
if you don't have the proper tool a pair of needle nose may do it, i have done this in a pinch before..
the piston in the rear has 2 slots in it. if you don't see wedge shaped slots your looking at the wrong thing. the piston is the thing with rubber around it that presses against the pad
ok try and turn those slots with the needle nose, if you can'y then buy the kit too compress the piston, or try autozone they may lend it too you
and if you tried too compress it with a c clamp then while your at the autozone buy a caliper for the side you trid that on.
i'm back, i borrowed a c clamp from my neighbor. he helped me out ( by the way he has 70 cuda 340 RT i think). i let him go drive the car and he noticed alittle brake squeal and rubbing sound when coming to a stop but no burning smell or off ballancing problems when braking or accellerating. we're going to compress the piston down again tommorow.
:jaw: no way in hell that piston went in with a c clamp... if it did it's all busted up inside now and inop
the rear brakes on our cars are the screw in type piston you can not force them in so your either lying ( i doubt this) or more likely you just destroyed your calipers...
thats funny because i just put a c-clamp on my fronts tonight while putting my front end back together i decided to get new pads while i was at it and it went in just fine and it damage the pad at all. And yes you are right, i forgot the rear are screw in type.
yeah the fronts are regular pistons. can c clamp those. and not tring too be cocky but i am a ford tech i have done lots of rear brakes on these and the taurus that has the same setup in the rear (if it is a disc brake car) so i know i am right.
he trashed his calipers, i doubt his e brakes work now. or for that matter it may not have rears at all now
not tring too flame whoever said c clamp it. but you need too be carefull when giving tech advice, if he did crush them down with a clamp he now needs too spend a couple of hundred in calipers
the rears on our cars needs too be twisted back in... any other design you can push back in with a c-clamp, big vise grip, channel locks or whatever
but this particular design for the rear is a twist in piston. i don't even want too know how hard you need too push to get it too go back in straight.
maybe him or his friend was smart enough too see this and twisted it while pushing a little.
that sux!!!!!!! :eek: that is why everyone should spend $20 and buy a shop manual for their car. In the service manual it tells you exactly what tools you need and exactly what you have to do. boards like this are a good place to get tips and openions, but dont treat it like a bible because people make mistakes and give wrong info. not trying to flame whoever said to use clamps the were just offering an openion. just be careful what you post is correct and if you listen to the post, make sure you double check it with some other source.
97gtconv. said:
yeah, i'll admit it that i broke something in left caliper rear one. The right one was making noises so i just said screw it and took it in. it's at the shop getting new pads calipers and hardware. Live and learn
i saw somebody tell you too push them back in with a c clamp. i tried too get too you before you compressed the caliper back in.. the rear calipers on our cars is a twist in style.
