  • SN95 4.6L Mustang Tech
What to do?
  • Thread starter Thread starter xruiz
  • Start date Start date Sep 8, 2005
xruiz
31
Houston,TX
Sep 8, 2005
  • Sep 8, 2005
Ok guys here's the deal, I'm debating on wether to get a set of gears or a shift kit for my auto tranny. I need to know what you guys think would be the best thing to get. I do ALOT of driving on the highway at around 80 if that matters at all. Thanks in advance.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Sep 8, 2005
  • Sep 8, 2005
Gears. You will need a Predator to correct speedo. The Predator will firm up the shifting of your transmission. You will get both things you want.
Also, make sure to add tranny cooler when increasing line pressure (firming up shifts)
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Sep 8, 2005
  • Sep 8, 2005
get the gears and the predator you wont regret it
mdvaldosta
72
  • Sep 8, 2005
gears definately, worry about a higher stall converter if your gonna be running sticky tires at the track. Gears will give you all the power you need plus some to break the tires loose off the line.
Mirrahasmycar
210
CT
Sep 8, 2005
  • Sep 8, 2005
the gears will make it wind out a little at 80, but it will give you a noticible boost in acceleration
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 8, 2005
  • Sep 8, 2005
Both
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Sep 9, 2005
  • Sep 9, 2005
Gearbanger101 said:
Both
Before doing anything to your transmission, I have to push the idea of a transmission cooler your way first. I can not stress how important these things are. Heat is the number 1 killer of automatic transmissions. A transmission cooler will reduce heat build up in the transmission. Many companies manufacture transmission coolers. I personally use the one from Steeda. I've had it for about 4 years now, and it works great. My brother uses one from Flex-a-lite in his with no complaints or problems with the cooler. B&M makes some nice ones, and if you have the money, you can dig deep and get one with an electric fan on it to help increase cooling abilities. Either way, be sure to get a transmission cooler.
Next, read these articles to learn how your transmission works.....
http://www.tccoa.com/articles/tranny/transmission/index.shtml
Pay closer attention to the articles on the 4r70w automatic transmission. Though it is a Thunderbird and Cougar club, the articles still pertain to the 4r70w transmission, which is what we use. You can trust this information, as the guy who wrote the articles was a former Ford transmission engineer.
Special Note: The 98+ 4r70w automatics already have the rubber bonded accumulator pistons, and the internal clutch plates are fine for a n/a application under 400rwhp. So, don't worry about upgrading those. The only thing you need to do is modify the valve body seperator plate holes and accumulator spring pistons. Keep that in mind when reading the following articles in the following links.
For the shift kit, you can find more info here on how to install the shift kit....
http://www.tccoa.com/articles/tranny/transmission/shiftybusiness.shtml
To learn how to modify the stock valve body for the Jerrys' specs, read here....
http://www.tccoa.com/articles/tranny/shiftybusiness.html
As for gears, it all depends on what your future plans are. If you're planning on adding a power adder in the future, like a supercharger, then 3.73's would probably be more ideal. If you're staying n/a, then 4.10s or 4.30's is what I recommend. I run 4.30's in my car every day and I have no complaints.
After doing gears to your car, you will need a ECU flash or chip to correct the speedometer and shift points for the new gears. I recommend getting a custom built program or tune from Superchips Tuning. Thats what I have and it works great.
If you have any other questions, feel free to ask.
xruiz
31
Houston,TX
Sep 9, 2005
  • Sep 9, 2005
What gears would you guys recommend for a daily driver, I drive it on the freeway every day at around 80mph. Also, another thing that I wanted to get is an h-pipe but i need your help guys.
joshheat25
871
Delaware
Sep 9, 2005
  • Sep 9, 2005
I have a 2000 gt auto and if you drive 80 on the highway you should go 3.73's. I have 4.10's and cruising at 75 it tachs over 3,000 at 70 it is at 2,700. But if you can drive slower get the 4.10's lol
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
Sep 10, 2005
#10
  • Sep 10, 2005
  • #10
I drive my car every day with 4.30's, and they perform just fine. As for the h-pipe, it all depends on what your future plans are. If you're planning on upgrading to long tubes, then wait until them before purchasing a mid-pipe, because the mid-pipe designed for the stock headers will not fit long tubes, unless if you cut it and modify it to make it fit.
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
H
Drivetrain 6R80 to t56 swap
  • Holymoses
  • Apr 25, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
AeroCoupe
C
Bored with my 73
  • Curtis Harper
  • Apr 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 23, 2026
RaggedGT
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
