What to fill holes on gt40 Aluminum heads?
green95gt
52
cartersville ga
There are a few treaded holes on my gt-40y aluminum heads. I'm pretty sure they are for emmisions stuff. Since my mustang has no emmisions equipment on it, does anyone know where I can find inserts for these holes? :shrug:
Thanks in advance.
You will need a threaded insert known as a thermactor plug. They screw into the back and front of your heads. Put silicone on the threads to prevent any exhaust leak when installing them. The thermactor plugs you will use for the front (same as back) will go to make the head holes smaller so the accessories can bolt up like your power steering stud and one of your bigger alternator bolts that go through you alternator bracket. The back thermactor plugs you will use just block off and delete the smog equipment’s previous hookups. You can get them at a Ford Dealership - part # F4ZZ-6E086-A or you can buy some from Summitracing - part # TFS-51400265 and they run anywhere from $3 to $12 dollars from what I have seen. Summit has them cheaper.
exactly what i was going to say. the bolt thing will work but the plugs from ford are the better way to go. just use anti-seize on them for later if you swap the heads to either side.
