what to get from junkyard?
Jaswir
578
Orlando, FL
like what other things i could get at a junkyard that i can use on a mustang...
looking at stuff to sell...
i know to get electric fan from a tauras 3.8L and mark 8
any others?
whats some stuff to get off the 5.0 motor? brackets? PS and AC?
94-95 front spindles (not the easiest to pull)
03-04 Cobra & bullitt 17" spare tires
87-93 Hatch covers
87-93 Cheese graters
85-86 Gt lenses
87-93 sail panel windows
94+ MC and booster
SN95 dist cover
Fox shifter boots and center console parts
Fox window trim
Axles - 83-'92 Ranger/Bronco II Left (driver) side axle (29-5/32") from a 4cyl or 3.0L V-6 with the 7.5" rear end, or '86-'97 Aerostar RIGHT side axles (29-5/32"), drums
Belt Tensioner, Mass Air Sensor, brake prop valve, wiper motor (useful for core), air conditioning knobs, 5 lug spare tire.
If you see a early 80's Crown Vic LTD check and see if it has the 351 windsor in it. The oil pan and pick up tube you can sell as a 351 fox body engine swap. It fits perfectly why I know because I found one and put the oil pan on my 351 and stuck it in my fox. no problems
