After you remove the bolt, rethread it back on just a few threads. Then grab the wheel with both hands, brace your feet and pull back with one, even, pull. The wheel will pop off and the bolt will not allow it to smack you in the face.
I have removed my steering wheel 3 times and I did it by hand every single time. I'm not the strongest guy in the world, so if I can do it, you can do it.
MAKE SURE YOU HAVE THE TIRES STRAIGHT WHEN YOU PULL THE WHEEL OFF!!! If you dont you are gonna have to put the new wheel on, straighten them, pull it off and then put the steering wheel back on straight.
I thought the steeringwheel could only go on two ways, correct and 180* out. There are two flat spots in the splined shaft, so you can't put it on just slightly askew.
