What transmission do i have?
These are all the numbers i could find on it.
e6zr7003 fb rep ati
13-52-169
71624 0207
It also said Borg/warner on it.
Also my speedometer isn't working so i looked under the dash and there is nothing attached to it , i couldn't find anything on the tranny where a speedo cable would go. So do these cars use a cable speedo or an electric speedo? and what can i do to get it working?
Thanks ahead of time!
If you are referring to the car in your signature, it most likely has a t-5 if it's a borg warner. The speedo is cable. It hooks up to the transmission through a speed sensor that connects to the tailshaft of your transmission. The speed sensor has a plastic speedometer gear on the end of it.
Ok but where on the tranny is the speed sensor? top , bottom , side? I looked but didn't see anything for a speedo.
attachment.php
See http://www.ttcautomotive.com/English/onlineorder/product.asp to download a FREE service manual for T5 or Tremec 3550
You will need the Adobe Acrobat viewer which is also a free download – http://www.adobe.com/products/acrobat/readstep2.html
See http://www.hanlonmotorsports.com/ or http://www.ddperformance.com for parts
The speed sensor is on the tailshaft of the driver's side. It is cylinder shaped and made of black plastic. If you do a search on 5.0 resto, you will be able to find a picture of it.
