What will my future combo yield?
  • Thread starter Thread starter vpap1
  • Start date Start date Jan 20, 2010
V
vpap1
109
  • Jan 20, 2010
What will my future combo yeild
Currently: 217whp and 278wtq
stock bottom end
stock e7 heads
bbk shortys
screamin demon ignition
edelbrock performer intake
spectre cold air intake
off road H pipe
flow masters
stock tires rims
Future:
80 mm Maf
75 mm TB
TFS tope end kit track heat
fuel pressure reg BBK
255 lph fuel pump
hydraulic roller lifters
egr delete
ac and smog delete
electric water pump
4.11's
what will i get at the wheels, hoping for high 12's on motor, so 300whp??
also looking at a 150 shot nitros
hoping for mid high 11's on juice??
so 420whp??
thanks
V
66sprint6
131
Jan 20, 2010
  • Jan 20, 2010
You should be all over your goals!!! I had old school twisted wedge heads, TFS1 cam, street heat intake, 65mm TB, lightning maf, BBK shorties and 3.55s and laid down 267rwhp/283tq and ran a best of 8.13 in the 1/8 mile which loosely translates to hight 12's. Was a fun fun setup, you wont be disappointed!
Matt
keepinitril
102
Anaheim Hills
Jan 20, 2010
  • Jan 20, 2010
are you upping your injectors!?
V
vpap1
109
  • Jan 20, 2010
yea probably 36 # injectors
V
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Jan 20, 2010
  • Jan 20, 2010
36# are a bit overkill IMO. With the tfs kit you'll probably see 300ish if it's a manual car. If you can drive, you can get into the 12s.
What nitrous kit are you planning to use?
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jan 20, 2010
  • Jan 20, 2010
Yeah i would say without the bottle you should see about 300/320. With good tires,ans syspension i'd say 12.8-13.1 at about 100MPH.I'm gonna be leanning more to the 13 flat times tho. peace
john
V
vpap1
109
  • Jan 21, 2010
nice, i will go ith 30# injectors , should cover it. any other mods or changes i whould think of??
V
Rick 91GT
Mustang Master
95
99
PA
Jan 21, 2010
  • Jan 21, 2010
300RWHP shouldn't be an issue with that combo, Id also suggest the 30# inj. They no longer make the 80mm MAF so youll have to go 75mm or 95mm
FWIW- You can go 12's on what you have with some suspension work and a good pass. Back in the day I was able to take my stock 169,000 mile motor 12.89 @ 104mph, 1.60 60ft and I am a very good driver...took some practive
F
FastStang91LX
31
Minnesota
Jan 21, 2010
  • Jan 21, 2010
Rick 91GT said:
They no longer make the 80mm MAF :
You can still do 80mm MAF if you use the cobra one, which is what I'm going to use. Also, I have TF 185 CNC heads, Track intake, and Stage 2 cam, and 30's is all I need, so I would only get 30's or you could have fuel problems. Also make sure your pump is up to the task. I also assume that you have a FPR already....
300 at the wheels should be close, I am only expecting about 400ish at the crank, so about 340 at the wheels
66sprint6
131
Jan 22, 2010
#10
  • Jan 22, 2010
  • #10
I actually ran my 8.13 on stock 19lbers, stock fuel pressure regulator and stock fuel pump. When we replaced the pump, injectors, fuel pressure regulator and mass air meter it was thrown on the dyno for a safe tune which actually seemed to slow it down some. I dont recommend you run it that way, but I did for a couple weeks daily and 3 or 4 track visits no problem! Make sure, whatever you do, you get a good tune. It will not only make it all work together, but it will make sure everythings safe and happy.
Matt
V
vpap1
109
#11
  • Jan 24, 2010
  • #11
Now , is there a cheaper head cam intake package I can use to get into the mid high 12's for less than 2500 bucks ie explorer heads, comp cam, and cobra intake ??? Obviously still doing the fuel upgrades and such and then still hit mid 11's on 150 shot of nos ???
thanks
V
Rick 91GT
Mustang Master
95
99
PA
Jan 25, 2010
#12
  • Jan 25, 2010
  • #12
thanks
V
The Trickflow Track Heat kit
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
So confirming what I need to do to put a '88 CV 302/AOD in my '65 A-code.
  • 1320stang
  • Apr 19, 2023
2K
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2023
1320stang
Thinking of selling my 95 GTS
  • #16Stang
  • Jan 20, 2022
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2022
nickyb
New to me Fox body. Looking for Rough HP and compression ratio
  • Halford4491
  • Oct 30, 2021
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 3, 2021
General karthief
