What will stock fuel pump do on 400hp stroker?
5liter87
26
Just wondering...I had a full tank in my car before doing the 331 swap (which isnt completely hooked up yet FYI), and im not sure what I should do about the fuel pump...I plan on purchasing a 255lph walboro...but havent been able to find a decent Syphon pump. If i was to get the motor running with the stock pump would it run lean and blow?? Or only if i beat on it, and floored it. Would i be able to just drive it around till she was bone dry, and then change the pump, or could this be dangerous for the motor which already has 5k on it. Any ideas? thanks guys...
Theres no point in stopping at halfway tho right? might as well get as much as possible right? I hope i can find a decent syphon kit, last one cudnt even get water out of the sink
I would think the stock fuel pump wouldn't do well with anything much over idle on a 331. I can't say for sure, but I wouldn't risk it myself. Why so hard to just siphon it? All you need are one of those primer bulbs and some fuel line, once you get a good flow going, it does the work by itself.
I just recently put a 331 stroker in my 89 GT and I can tell you right off that you definitely need to change the fuel pump. I had the stock one in mine at first, and it ran way too lean. Just last weekend I put a 255 in it with an adjustable fpr, and the sum bitch is making big horsepower. I havent had it tuned just yet, but its supposed to make around 450 horse at the rear wheels. Back to your question, you would be ok just running the fuel out if thats what you decide to do. Good luck on yours, i'm almost finished working the kinks out of mine.
Here are some useful tips...
I have done the tank removal three times, and the main issues are getting the car up on jack stands and getting the gas out of the tank. DO NOT try to do this job without jack stands. Becoming a pancake is not part of the repair process.
Pumping out the old gas:
If the old pump still works, you can use it to pump the tank out.
1.) Separate the pressure line (the one with the Schrader valve on it) using the fuel line tools.
Look in the A/C repair section for the fuel line tools. They look like little plastic top hats. You will need the 1/2" & 5/8" ones. The hat shaped section goes on facing the large part of the coupling. Then you press hard on the brim until it forces the sleeve into the coupling and releases the spring. You may need someone to pull on the line while you press on the coupling.
Use a piece of garden hose to run from the pressure line to your bucket or gas can. Make sure it is as leak proof as you can make it. Fire and explosion are not part of the repair process...
2.) Jumper the fuel pump test point to ground.
attachment.php
Turn the ignition switch to the Run position. the fuel pump will pump the tank almost dry unless the battery runs down first.
Some 5 gallon paint pails lined with garbage bags are good to hold the gas. The garbage bags provide a clean liner for the pails and keep the loose trash out of the gas so you can reuse it. If you decide to use a siphon, a piece of 1/2" garden hose stuck down the filler neck will siphon all but a gallon or so of the gas.
Remove the filler neck bolts and put them in a zip bag. Disconnect the supply & return lines by removing the plastic clips from the metal tubing. If you damage the clips, you can get new ones form the auto part store for just a few dollars. I have used tie-wraps, but that is not the best choice. Then you remove the two 9/16" nuts that hold the T bolts to the straps. Put the nuts in the zip bag with the filler bolts. Pull the plastic shield down and away from the tank. Once the tank drops a little bit you can disconnect the wiring for the pump & fuel quantity sender.
The pump/fuel gauge sender assembly comes out by removing a large metal ring that unscrews from the tank. You are supposed to use a brass punch to tap on the ring so that you don't make sparks. Look closely at the rubber O ring gasket when you remove the sender. The pump assembly requires some twisting and turning to get it out the hole.
Look very closely at the electrical wiring. The stock fuel pump wiring can overheat and melt the insulation. Mine had some really crummy plastic tubing slid over the quick disconnects. If the wires ever got together, there would be sparks inside the fuel tank and no more Mustang. I eliminated the splice in the middle of the wiring and went straight from the pump to the feed through connectors for the wiring. It required some soldering and crimping of new tabs on the wires, but it made a neater job.
Inspect the pump mount to metal tubing bracket. Mine broke and I couldn't get it to solder back together. I drilled a small hole for a machine screw & self locking nut to hold the clamp and bracket together.
The pump is easy to get off the mount but is somewhat difficult to get back it the tank without damaging the sock filter or tearing it on the tank baffle. When you install the metal ring that holds the pump in place, watch out for the gasket O ring. Some RTV may be helpful if the ring is not in excellent condition.
The tank to filler pipe seal is a large rubber grommet. Inspect it for hardening, tears and damage. At $20 from the Ford dealer, it might be a good idea to replace it.
I used a floor jack to help lift the tank back in place. You may find that it is the only time you really can make good use of a helper.
