What year is my Transmission????????????
Georgie
455
Montreal, Canada
its says borg warner on it... this is what the aluminum TAG reads : E6ZR-7003-FB REP-AT1 13-52-169 17003 01162
PLEASE HELP GUYS.. CUZ I GOT THE STOCK AOD REAR END..AND IM SWAPIN IN THIS T5... BUT I NEED TO KNOW WHAT YEAR IT IS SO I CAN GET THE RIGHT DRIVEN GEAR.... THNX
:SNSign:
86.5 - 89
If ytou want to narrow it down evern further look for the casting date on the trans. There is one on the top cover on the pass side and another on the main case on the pass side. It looks like a circle with a number in it. That's the year the part was cast in.
Should be a yellow 7-tooth gear, look inside the hole for the speedo, you should see it
OK i drained and opened the rear end...i counted the gears and gave me a ratio of 2.73... what driven gear do i need??? in the speedo sensor...
I'm only missing the driven gear for my whole parts list for the AOD to T5 swap!!!! :hail2:
thanks guys! :nice:
Speedometer Recalibration Gears
Once you change the gears in your differential, you need a new speedometer gear to recalibrate your speedometer. They're inexpensive, and only take a few minutes to change.
These Recalibration Gears fit 1979-1998 Mustangs. Please check our Hot New Product Section for information on 1999 and 2002 Mustangs.
Instructions: Note transmission type, model and resulting drive gear. Cross reference with your rear-end gear ratio to find the correct "recalibration" gear for your application.
Manual Transmissions with 7 Tooth Drive Gear
1983-1989 T-5 OEM
Pre 1993 T-5 Aftermarket
1996-1998 Cobra T-45 OEM
All Tremec Transmissions
2.73 Gear Ratio / Maroon 16 Speedo Gear $9.95
3.08 Gear Ratio / Yellow 18 Speedo Gear $9.95
3.27 Gear Ratio / Pink 19 Speedo Gear $9.95
3.55 Gear Ratio / Black 20 Speedo Gear $9.95
3.73 Gear Ratio / Red 21 Speedo Gear $9.95
4.10 Gear Ratio / White 23 Speedo Gear $15.95
Manual Transmissions with 8 Tooth Drive Gear
1990-1995 T-5 OEM
1996-1998 T-45 OEM Except Cobra 2.73 Gear Ratio / Yellow 18 Speedo Gear $9.95
3.08 Gear Ratio / Black 20 Speedo Gear $9.95
3.27 Gear Ratio / Red 21 Speedo Gear $9.95
3.55 Gear Ratio / White 23 Speedo Gear $15.95
3.73 Gear Ratio / White 23 Speedo Gear $15.95
Automatic Transmissions with 7 Tooth Drive Gear
1983-1989 Automatic Transmissions
2.73 Gear Ratio / Blue 16 Speedo Gear $9.95
3.08 Gear Ratio / Gray 18 Speedo Gear $9.95
3.27 Gear Ratio / Tan 19 Speedo Gear $9.95
3.55 Gear Ratio / Orange 20 Speedo Gear $9.95
3.73 Gear Ratio / Purple 21 Speedo Gear $9.95
Automatic Transmissions with 8 Tooth Drive Gear
1990-1998 Automatic Transmissions 2.73 Gear Ratio / Gray 18 Speedo Gear $9.95
3.08 Gear Ratio / Orange 20 Speedo Gear $9.95
3.27 Gear Ratio / Purple 21 Speedo Gear $9.95
