- Sep 26, 2009
- 6
- 0
- 0
what years did the flywheels change on the 5.0l and the 5.8l and to what imbalance weights? being told different things from people, getting all confused, not willing to chance it. also whats the difference in the 10, 10.5, could i still use the same starter and housing?
, and now need to buy a flywheel and clutch for my 5.8. for the sake of price, im looking to buy one for a 5.0 (knowing its compatible with the 5.8) for the 5.8. i only recently relized there are different sizes, imbalance weights, and teeth within the different years (guess i got lucky with the miss matching). what i understood with my research was, the 85'earlier had 28oz weights 10" clutch 157spline ring gear(so im assuming the 5.8 needs a 28oz), and the 86' later has 50oz weights and a 10.5"clutch 157spline ring gear (PLEASE correct me if im wrong) soooo.... my question is: would it work with the 351w to to get a 86 or later flywheel with a bolt on "28oz" weight and a 10.5" clutch (the bigger the clutch, the better, right?)and still use the same bellhousing and starter that i had with the 85" setup? if not, what would work, or be recommended?
