Whats all involved with engine swaperoo!!!
I recently updated the info on my website for the swap. See link in my sig.
I will post it here later (I can't access my site from work).
Keep asking questions if it doesn't make sense.
Good Luck with the swap, it is a blast.
jason
EDIT: what are you putting the 351w in?
Ok just read the page, well tried, im on some myquill right now as well as sudaphed or somethin like that, my eyes are goin crazy!! So basically the flywheel, oilpan and pickup and intakes and fuel rails, will the stock rails off the truck its in work? Ill prolly swap it in it my parental units approve it, yeah dad it'll be "stock"!! LOL How much is it to rebalance the flywheel?
Thanks again, josh
Thanks again, josh
LOL
When I started my 351w swap, I had just had knee surgery. Just removing the spark plugs was a challenge, due to the pain pills.
Has this car been converted to MAF?
What has been done to the car to this point?
It would be easiest to use the stock Mustang fuel rails, and extend the rubber hoses by replacing them with high pressure lines.
The truck fuel rails hook up (to the supply and return lines) in different locations, and the regulators may be relocated as well.
I think the flywheel rebalance was about $90.
jason
slow95gt said:
Oh forgot to add this: the bellhousing off a 5.0 5sped will work with a 351 right? Do I have to have a shorter driveshaft? can I run my king cobra clutch on it also? And whats up with the alternator bracket and the accessories.
Thanks Josh
The bellhousing will work, as well as the stock driveshaft.
I am not certain on that clutch, but it should be ok.
I ran my CF dual friction clutch when I swapped to 351w.
You will need to worry about the P/S and A/C. There is a bracket that you will need from Ford. Ford makes then for p/s only OR p/s and a/c.
The alt bracket swaps right over.
jason
