  • 2005 - 2009 Specific Tech
What's causing this??
  • Thread starter Thread starter darien87
  • Start date Start date Aug 18, 2009
darien87
132
Bay area, California
Aug 18, 2009
  • Aug 18, 2009
I've had my 07 for about 6 months now and I love it. One of the first thing I did was swap out the stock 18" rims for some 19's, (see sig for tires). When I brought my car back to the dealership to get serviced they rotated the tires and I started getting a noticeable shake in the steering wheel from 60 MPH to about 70.
I have taken my car to Firestone twice to have the tires balanced and the shake is still there. Is there something else that could be causing this?
gallags
28
  • Aug 18, 2009
Some tires have arrow pointing to the correct rotation if you have them pointing the wrong way that may be causing your problem it’s a good place to start. Also have you tried putting back tires the way they were before the rotation?
F
fallenauthority
72
Hughesville, MD
Aug 18, 2009
  • Aug 18, 2009
You probably had a bent wheel on the back, and its now on the front. Take it to a wheel repair shop and have them check the front wheels to see if either of them are bent. You wont notice it until they are swapped to the front, so thats why you might not have noticed it with it on the back.
darien87
132
Aug 18, 2009
  • Aug 18, 2009
I hope not. The rims were new. But I guess you never know.
DarkFireGT
Playing with my wife's really makes me want one.
692
10
89
East Moline, IL
Aug 18, 2009
  • Aug 18, 2009
Pull your wheels off and make sure all of the little clips have been removed from the lugs. The factory puts them on to make assembly easier, but they cause aftermarket wheel shimmy. I had 2 on each corner. The look like a thin lock washer.
newskool
251
37
48
Fayetteville, NC
Aug 18, 2009
  • Aug 18, 2009
Retaining clip thread part 2.
SpartaPerformance
2,517
61
89
Long Island NY
Aug 18, 2009
  • Aug 18, 2009
Not a bad to check you rims for hub centric spacers, if you were only given two they might have needed up in the back with the previous front rims. You may also have a bad rim/tire. I know every tire place puts the wheels with the most balance weights in the back when tires are installed.
T
TestMe
28
Lubbock TX
Aug 18, 2009
  • Aug 18, 2009
i had the same problem when i had my tires balanced and rotated. dealership didnt tell me they put spacers in there. a local tire shop took em out and have had no shaking since.
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
O
Good all around perfornace-ish tires?
  • optionizerSS
  • Jan 25, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jun 15, 2026
TPony
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
K
Intense Shaking problem
  • KP_NewEdge
  • Jun 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 11, 2025
gkomo
