whats needed for t-56
  • Thread starter Thread starter stangraccer
  • Start date Start date Nov 22, 2005
stangraccer
203
9
Spring Grove, PA
Nov 22, 2005
  • Nov 22, 2005
I'm about to put a new transmission in my 1990, and am seriously thinking about either the tremec 500 or the t-56, what will I need in order to install these? Can I reuse my Centerforce clutch in either of them? with the t-56 will I need a different clutch or drive shaft? thank you
soontobefastfox
275
Troy, Michigan
Nov 22, 2005
  • Nov 22, 2005
to swap in a t56 you are going to need:
-driveshaft
-26T disc clutch
-crossmember
-bell housing
-shifter
-speedo cable
I think thats all you need.
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Nov 22, 2005
  • Nov 22, 2005
The clutch depends on the input shaft of the new trans. If you have a 10 spline clutch then it won't work with a 26 spline TKO or T56. As for fitting the T56, you will have to get a shortened d/s and different cross-member. From what I remember, it may require some cutting if you have subframes. Check out D&D as they have a whole kit for installing the T56 in a stang:
http://ddperformance.com/T56 Kits.htm
6SpeedLX
100
Mass
Nov 22, 2005
  • Nov 22, 2005
the basic T56 has a 10 spline input shaft so you can use any clutch for a T5. the Viper spec however is a 26 spline..i have the basic kit from D&D and it comes with everything you need...the transmission crossmember relocation brackets come to fit around subframe connectors...everything is very good quality...the conversion is straight-forward and all you have to remember is to wire the Neutral Safety Switch together or youll never get it to start. i did it in my garage with 4 jackstands and a floor jack.
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Nov 22, 2005
  • Nov 22, 2005
A hefty budget would come in handy too, hah
soontobefastfox
275
Troy, Michigan
Nov 22, 2005
  • Nov 22, 2005
yep, you better have some cash to tackle this project. Why not a tko? Its a little cheaper...
stangraccer
203
9
Spring Grove, PA
Dec 8, 2005
  • Dec 8, 2005
Yeah I've decided to just get the TKO along w/ an aluminum driveshaft and adj. quadrant, thanks for the help guys!
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Dec 8, 2005
  • Dec 8, 2005
With the TKO you will need to modify the crossmember, just grind down the spot welds so you can move it back and forth, either remove the exaust hangers to the midpipe or relocate them further back, and in my case, the driveshaft will fit but is too long, the yoke is pressed against the tailshaft. When my car gets back togeather, I will need to shorten it a lot, as well as a different crossmember because the K-member I have moves the engine back another inch.
The T-56 is awesome. .5 overdrive, you could run a hell of a gear. I don't understand why they can't make the TKO 500 or 600 with a really high overdive like that since 5th is just a highway gear anyways. Wouldn't it be great to run a 4.56 gear 1st through 4th, but then put it in 5th and cruise at 80mph at 2000rpm?
00-Saleen
588
Snohomish,WA
Dec 8, 2005
  • Dec 8, 2005
Yea but why have 5 gears when u can have 6! I have a T-56 in my garage with 7k Miles on it that i picked up for 1500$ straight up, along with the Driveshaft and an MGW Shifter.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
New Member 1969 Mach 1
  • 69Resto
  • Sep 19, 2025
  • The Welcome Wagon
The Welcome Wagon Sep 19, 2025
69Resto
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
