Whats next?91GT- expert advice?
bloopbloob
578
Alberta
Just looking for some advice on whats next? Just getting into the whole mustang scene and the hp bug has bit!! Rebuilt engine last year (back to stock plus p&p heads) which i know isnt the way to go but i didnt have the $$ or interest then.
Mods in sig, with subframes, ud pullies,water pump, 76mm c&l maf system, 70mm tb & spacer. Wheres the next place to start. I do plan on eventually getting some afr's, u/l manifold (suggestions???), and 3:73 gears, but those are all pretty expensive.... just wondering if there's any smaller stuff i could get some good gains from first, and then with the bigger stuff any suggestions? I'm a student living in an apartment, so the big jobs are not something i'm capable of doing myself currently..... but i do like to do as much as i can.
any mistakes i've made so far?
I'm by far an expert, but I can give some little advice.
Make sure that your upper intake tract, where the throttle body/egr plate bolt-up is matched to your intake opening.
Also, you could have the lower ported to match your heads. It will run you not to much over a $100 bucks and a man by the name of tmoss on this site can do it for you.
If you want to buy a new intake, something around the Edelbrock Performer or Street/Track Heat intake is nice for the price and flows good for a heads and cam equipped car.
AFR's are a good head choice, good pickings there along with other good heads out there.
you could get an explorer intake for pretty cheap...$100-200 depending on which one you get. some come w/ egr capabilities, some do not. then you'll have to start saving for the more expensive stuff: gears, cyl heads, etc. don't bother with a cam until you get the cylinder heads.
yeah. 2:73's. i know gears are pretty much the 1st mod to be done, but i dont think its something i can do myself, and most places around here want about 800 or 900 to install, which i think is BS. Ford dealership told me $700-800 for the parts and almost another $1000 for install. I pretty much told them that they can go f*** themselves. Told them i've seen FRPP 3:73s for $170 american all over the net, and they pretty much called me a liar....
Do a lot of research on the net and do the gears yourself. Its not that hard, you do need a few specialized tools that are not expensive. If your old bearings are good, the most it will cost you is ~$250 for gear set, parts and tools.
