Since i installed heads i have little problem with heat, i don't have overheating it just runs hotter than before
I run 160F thermostat with adjusted fan sfitch by TwEECer but with 160 thermostat i keep melting fan motor connector because it runs at High speed all the time, so i have switched to 180 thermostat
I know there is Red Line Water Wetter but i was wandering whats the best coolant mixture ( watter / antifreeze)
I heard with too much antifreeze will runs hotter because lower boiling points
How about 100% water
Why would you recommend using that stuff? I have to respectfully disagree 100% about that recommendation (unless you know something I dont).
