Whats the diffenece between brake pedals?
  • Thread starter Thread starter Stang_1973
  • Start date Start date Jan 22, 2009
Stang_1973
565
9
38
San Antonio, Tx.
Jan 22, 2009
  • Jan 22, 2009
So i know im going to swap for disk brakes real soon. However, For another 150 bucks i can get power over manual disk brakes.
So here my question, if go this route DO i have to swap out the brake pedal as well? If so is it just the pedal or is there more to it?
zookeeper
3,415
63
109
Rogue River, Oregon
Jan 22, 2009
  • Jan 22, 2009
Most kits are designed to use your existing pedal. Just let whoever you order from know if your car was originally equipped with power or manual.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jan 22, 2009
  • Jan 22, 2009
The difference between the pedals is the mechanical advantage that the pedal creates when you step on it. If I remember this correctly, a manual pedal will have a higher mechanical advantage.
Platonic Solid
1,960
CT-USA
Jan 23, 2009
  • Jan 23, 2009
If the shop manual is correct (using a 72 Ford Shop Manual) then the physical pedal assembly remains the same between original power disk and non-power drum. Pedal free height and travel are different.
Stang_1973
565
9
38
San Antonio, Tx.
Jan 23, 2009
  • Jan 23, 2009
OK.
Thanx guys! looks like ill be getting some power disk brakes!
jerry S
1,365
52.22N 5.12E
Jan 23, 2009
  • Jan 23, 2009
My car had manual brakes and I swapped to power disks. The power kit contained a longer pedal. Where the pedal mounts to a bracket on the firewall, there is a drilled out pivot point. There is an indented point on the top of bracket that you drill out in order to mount the pedal for power brakes. Look at page 3 of the following link.
http://www.mpbrakes.com/uploads/products/BM1521KA-Installation Instructions.pdf
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 2:14 PM
rednotch
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
A
Resolved Brake light switch
  • Alabama
  • Feb 24, 2025
4K
General karthief
D
Brakes 88 LX 5.0 - help! no brakes
  • DRGunn427
  • Feb 26, 2025
Fox 5.0 Mustang Tech Feb 27, 2025
nickyb
