brianj5600 said:Stock stuff is not cheap once you rebuild it and ports are not good at low rpm's.
that is a myth perpetrated by the windsor folks. on the street a stock cleveland with either 2V or 4V heads has plenty of low end grunt.
Hack said:http://www.chiheads.com/main.html
You could read about how CHI heads were on the 700 horsepower pump gas Cleveland that won the Engine Master's competition.
I'm not sure if there were Windsor style competitors, but the winner was the Cleveland. You don't see articles in magazines about CHI because they are little guys that can't afford big ad campaigns. But they know Clevelands and their stuff works.
Now what you want in your daily driver is not what was put in an Engine Masters competition, but "better" doesn't really have to do with picking up groceries down the block, does it?![]()
I love debating stuff like this! Fun.brianj5600 said:Stock stuff is not cheap once you rebuild it and ports are not good at low rpm's. CHI heads are nice, but for $2k i'll take the 205 afr's. The "good" C heads, better than inlines, are very expensive and have the ports raised enough that headers may be a custom deal on a classic. Sentimental or the fact that you have stuff laying around are the only reasons to go canted unless you are heads up racing, and then you need Yate's on Neal heads IMO. HP per dollar from scratch, the W will win.
Yes, in the real world you would run different compression or higher octane gas.180 Out said:The Engine Master finalists are DEFINITELY not the hot ticket for picking up groceries. Here's an edit of the write up of the '04 edition, won by a CHI-headed Clevor:
...snip...
In other words, one of these MIGHT get you to the A & P without the con rods falling out the bottom, but it probably will not get you home.
Starting from scratch meaning you don't even have a core.Hack said:I love debating stuff like this! Fun.![]()
Anyway, I disagree with your post.
1. stock W vs stock C (4V CC or OC) - C wins hands down. In fact, the stock C beats any manufacturer's engine from the 70's with similar cubes. That's why the Chevy guys like to call the C a big block.
2. modded W vs stock C (4V CC or OC) - could be close. Depends on how much you spend on the W.
3. modded W vs. modded C - C wins if you spend a comparable amount because you HAVE to buy aftermarket heads for the W to come even close to a Cleveland, and the C cast iron heads do not have to be replaced. That's a lot of extra money to upgrade the C.
5. ultimate modded W vs. ultimate modded C - W wins with aftermarket block, but C heads on an aftermarket block still beat the W.
I disagree that you need Yates high port heads to make big power with a Cleveland. The Engine Master's Cleveland didn't use high port heads.
And all but one got beat by a Chevy motor!ddonaca351 said:Did you notice how many engines in the engine masters challenge were C head motors????
