What's the max tire size for a fox body mustang...and few tire questions
Dip In Traffic
217
queens,ny
What's the max tire size for a fox body mustang..its been a while since i shopped around for tires and rims...
1)what size tire will fit under a fox with quadshocks
2)what size tire will fit under a fox with out quadshocks
3)what backspacing will i need for draglites in the rear 5.5 or 5.0
4)recomended size of slicks...
any reccomendations????
i know this is a stupid question but will any of the above fit under a 1" 1/2 drop???
Are you talking all 4 corners?
ALL 4, 245/45/16 or 17 fit nicely with no quad shock issues, atleast from what I can remember.
REAR, a 275/50/15 will fit nicely, no quads 15 x 8 rim 5.5 backspace (may need to roll lip a hair). If you want to do alot of hammering anf heating/beating a 325/50/15 on a 15 x 10 w/ 6.5 backspace will fit.
If you get the 15" x 8" draglite get 5.5" backspace, I'd also run a 26" x 8-9" slick for your application, or 26" x 8-10" DOT legal tire (ET STREET, BFG D/R, etc)
If you don't already have gears I'd suggest some 3:73's-4:10 (depending what your future holds) and a converter to really wake up the AOD.
lmao ignore my sig i need to update it i have a high comp 306 with 3500 stall converter :nice:
my car is lowered right now will i be able to run such a tire???without probs?? im a handling freak but i like straight line too any middle ground...ill get two sets of wheels's that not a prob.....
what are the width of :
stock 10 hole rims
stock pony rims
would i be able to fit 275/60/15 on either
1fastfox said:
hey i dont think mine was lowered previously but i got a combo rim/tire kit which was 17x8 in the front and 17x9 in the back and i only experience rubbing when I make really sharp turns (i.e cul de sac or sharp u turn)
what size rubber do you have and where did you get the rims from
stock 10 hole rims
stock pony rims
10 holes and turbines are 15x7, pony's are 16x7 (maybe 16x8, im not sure).
