whats wrong with a carbed motor?
KyleEBK
173
Was looking at this vehicle I wanted to buy and its carbed
how come people seem to steer clear of carbs any reason why? its a 86 convertible and its a long block is that bad?
Long block is just a term for an engine bottom end that has the heads bolted on. When you take the heads off, it's now a short block.
Carbs are just a personal preference. Most Fox guys tend to favor the EFI in terms of tunability. Carbs require a little more skill to tune.
Exactly, in my state a carbed motor in a car that didn't come with one will not pass emissions for sure.
Carbs are an old school way of tuning that not a lot of younger guys have experience with. In real cold conditions a carb might be harder to start/run, and in a cold to hot swing might need to be manually tuned to perform the same, which some people steer clear of.
If your not scared of a carb they are cleaner, easier to work on and cheaper to "tune".
EFI has been standard on cars for so long most guys don't understand how a carb works any more. In 1985 people were avoiding fuel injected cars because they didn't understand them and thought you couldn't work on them. now its the opposite. I have to re-learn all the carb stuff since I just did a 5.0 swap into an 84 an went with a carb. To me EFI=cleaner, better mileage, easier starting, no problem trips thru the mountains. Carb=cheaper to set up, cleaner looking engine bay, fewer parts/less complex.
People probably steer clear of the car because most likely it was originally an EFI car if it was an 86. I wouldn't go near an original EFI mustang that was converted to a carb either.
I'm not really sure if any early run 86's had carbs to begin with, maybe someone else can answer that.
I believe in putting newer setups on an older car, but not vice versa.
Some 86's came carbed from the factory I believe. I wanna say EFI came out mid year and they were still getting rid of the last of the carbed models in 86 as well. I could be completely wrong, but I seem to remember reading it somewhere not too long ago.
Ya, that's why i mentioned to check into it.
I've looked through alot of for sale ads to get an idea of if there was some factory carbs, but the only ones i found were heavily modified, beyond what a factory carb on a fox looked like so it was hard to tell.
I love my carbed 89 notch. i love the dual quad setup that i run in my 440bb. i hate EFI, in fact... carbs are just a lot easier to tune for me - just a twist of the screw driver. very VERY accessible, VERY tunable.
