what's wrong with this shelby?
You're right about the underriders being incorrect. All '65's and the first 200 or so 66's had the overriders. That looks like an 8" diff to me, too, which would also be incorrect. Could be a replacement of the axle along the way, which if it was a quickie repair prior to 1970, when originality didn't mean diddly, this would explain the switch to underriders, since the overriders had brackets that had to be welded onto the axle tubes.
So 150 grand gets you a "restored" shelby with a completely incorrect rear end, the wrong traction bar setup which would be very hard to replace and likely a wrong gear ratio (non 3.89) and probably no locker as well.
He did say the quarters were replaced so maybe the car had been hit and damaged the housing??
That looks like a stock 8' and its not a waffle case either so it is true to the pre 67' 8" rear.
Maybe the guy came across a totaled shelby and just swapped everything over, In reality that's all these cars were anyway. the fabrication on the rear and over ride traction bars would be the hardest thing to replicate correctly.
D.Hearne said:
I think you'd have to be a complete idiot to pay 150 grand for a car like that.
Not saying I disagree with you....however if you have 150 grand to spend on a car (shelby or otherwise)...you must be doing something right. It's all about priorities.
I think people buy these cars purely as investments now. Chances are someone will buy it, fix it to be factory correct and sell it.
mikemustang289 said:
The guy emailed me back, it is a 9" rear but his friend who he is selling the car for says that the traction bars are correct.
No they are not. He can claim what he likes but that does not make it true. The traction bars are not correct for an early production 65 Shelby....PERIOD. That is definitely a 9" rear but as has already been stated it does not taper down on the ends so it is either a fabbed one or a 57-59. This could easily be a rebody that was built from a heap of 65 Shelby parts or a partial car.
He certainly made a point to clearly state that the car was a Shelby and not a fake when I stated that the rear end made it appear to give the impression that the car is not in fact an actual shelby. I will email him again and see what he says.
What he says is irrelevant at this point if he claims the traction bars are original or correct. If he says the 9" rear in there is the original one he is lying again. What he says means little.
