  • SN95 4.6L Mustang Tech
wheel bearing ?
  • Thread starter Thread starter Movn GT
  • Start date Start date Mar 13, 2007
M
Movn GT
9
  • Mar 13, 2007
I have a 02 GT auto..when i go down the road i can kinda feel a vibration on the gas pedal..the car just don't feel right at all, and if i let go of the wheel it pulls to the right pretty hard. Think its a wheel bearing or bent rim ? A month ago i was turning a corner like 5mp and the tire blew out and i had to drive on it for like 50 feet so maybe the rim is bent ? Is there a way to check the wheel bearing ?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 13, 2007
  • Mar 13, 2007
Yes, raise the front of the car securely up on jackstands. Grab the wheel that is giving you problems with both hands and try to move the wheel in/out, up/down, left/right. There should be no movement. Also, spin the wheel and listen for nasty ginding sounds. There will be a bit of a grind from the brake pads...
I made a thread on hub bearing replacement here in 4.6 tech with pictures and prices of parts. Do a search for it for more information. If you DIY you are looking at about $110 per side to replace hub bearing assemblies and it is a fairly simple procedure. It is common for the hub bearing assembly to fail on these cars.
M
Movn GT
9
  • Mar 13, 2007
Will check it out this weekend..thanks.
speedfreak98r
Banned
Jan 31, 2006
Houston Area
Mar 13, 2007
  • Mar 13, 2007
Mine are grinding like crazy
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Mar 13, 2007
  • Mar 13, 2007
Could be a warped brake rotor.
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
