Wheel Fitment Guys; HELP!!!
sleeper89 said:
i don't think you'll have any problems up front, but you might need to remove the quads for clearance out back, or a swap to sn95 rear.
ttt for confirmation.
-steve
Thanks Steve, would like to hear some other thoughts also; I know there are guys on here running 18's..........
You'll be fine on the front, out back, worst case scenario, you might need a 1/4 in spacer and maybe drop the quads. It really depends on the offset of course, but that's what it took for me to get 98 GT split-spokes on my car with a 275/40/17 tire
HappyG said:
what you need to do is find our the offset, then you can have an idea, rim diameter doesnt matter.
I realize that; I have seen these actual rims on foxes (in pics) and thought someone might be familiar with the backspace. Guess I'll see if I can find the numbers and post back.
I have tsw revo 16 inch rims coming for my 88 mustang gt.They have a 20mm offset and are for my car.So I don't know if the offset changes for bigger diameter rims.I don't think it would.Offset is how much of the tire is in or out of the axle.Diameter should not change the offset.The 20mm inback is right and the 30mm in the front would put the front tires 10mm in more witch would make sense.The front always sticks out a little more then back.
