  • SN95 4.6L Mustang Tech
Wheel Spacers?
  • Thread starter Thread starter makdad
  • Start date Start date Apr 7, 2005
1 of 2 Next Last
makdad
387
Maine
Apr 7, 2005
  • Apr 7, 2005
Just wondering what size wheel spacers to get to get the stock rim out a bit in the back? anyone know?...I just dont have the money right now for the tires for the new rims...nut I want to get my rears out a bit 4 now..prob a waste of money but o well..i could always sell them when I am done wit em..any ideas?
makdad
387
Maine
Apr 7, 2005
  • Apr 7, 2005
o by the way 96 gt
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 7, 2005
  • Apr 7, 2005
Just saw these ones in the trader.
You wouldn't want to go much more than 1" to 1 1/4" anyway.
http://classifieds.stangnet.com/showproduct.php?product=16858
makdad
387
Maine
Apr 7, 2005
  • Apr 7, 2005
Yea i saw those 2...thats y i was asking...lol..thanks 4 the info on the sizes
allcarfan
The Answer Man
2,458
North Atlanta
Apr 7, 2005
  • Apr 7, 2005
I would go with 3/4" wheel spacers. You can look on ebay and have them custom made to your specs for $75/pair or $140 for all four. I have all four and couldnt be happier. You may also try emailing wheeladapters@aol.com
Shane
stangman
2,690
10
69
in a 3 bed, 2 bath
Apr 7, 2005
  • Apr 7, 2005
PM mcmotorsports. he just put spacers on his, & whatever size he has looks perfect
85MustGT
95
Occupied San Diego
Apr 7, 2005
  • Apr 7, 2005
Why -
Is it cosmetic or does it stabilize the ride a bit?
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 7, 2005
  • Apr 7, 2005
85MustGT said:
Why -
I suppose to a very small degree it will increases stability, but in this case, it's mostly cosmetic.
mcmmotorsports
689
Danbury, CT
Apr 7, 2005
  • Apr 7, 2005
It is primarily for appearance, BUT, a wider tread width does improve handling.
No need to PM me for pics, here they are:
1 1/4 inch
I like them alot, they make a huge difference in the stance of my car. I will be selling them in a few months once I have enough $$$ for my Black Bullitts.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 7, 2005
#10
  • Apr 7, 2005
  • #10
True....but that's only if you're upgrading your wheels and tires along with it. If you're still running your stock wheels along with the set up (like makdad said he would be) then the additional 2" or so of with is going to provide a marginal improvement, at best.
GDawg
1,469
Nevada
Apr 7, 2005
#11
  • Apr 7, 2005
  • #11
I have 30mm (1-3/16") H&R spacers on my rear. Once I lowered my car the rear wheels looked way too inset. The spacers have definitely improved the look and I haven't scrapped on my tires yet (knock on wood). These pictures aren't the best but I think you can see the difference.
Before I put on the wheel spacers (after lowering)...
After I installed the spacers (and smoked headlights)...
I had to grind down the wheel lugs but not too much.
The spacers...
My pets after the change.... (j/k)
LI98GTStang
1,715
L.I., NY
Apr 7, 2005
#12
  • Apr 7, 2005
  • #12
Looks good GDawg!
Here's a pic of mine with 1.25" Wheel Adapters and the stock rims. No trimming of the stock studs were necessary.
stangGT97
1,299
Boston area, MA
Apr 7, 2005
#13
  • Apr 7, 2005
  • #13
1" wheel spacers on mine, gives it a nice wide stance in the back. i'd say go with a 1" or a little bigger spacer.
mcmmotorsports
689
Danbury, CT
Apr 8, 2005
#14
  • Apr 8, 2005
  • #14
On some rims you do need to shave the nipples on the ends of the studs. No threads on the studs were harmed during this modification, so all is good.
R
rs-turbo
397
Orlando, Florida
Apr 10, 2005
#15
  • Apr 10, 2005
  • #15
I just bought some 1.25" at the Daytona Sping show last month and installed them. Looks good, but I'm finding they rub whenever I go over bumps. This weekend I had the car loaded going to the Mustangs and Mustangs show here in Florida, and scraped over every bump on the highway it seemed. Don't like the idea of my fenders now being the bump stops and tearing up the edge of my tires.
I didn't need to shave anything with the 1.25" but the tires are being shaved now What width will work best and still clear the fenders? I have Steeda Springs and Tokicos and want to keep my stock wheels. I'm only looking at doing the rear ones to get a wider looking stance and fill in that gap.
Also, will doing just the rear effect the alignment and wear characteristics, and can an alignment still be done at the local tire shop?
donyw
64
Long Island, New York
Apr 10, 2005
#16
  • Apr 10, 2005
  • #16
Are there any safety issues with these to be concerned about. I have a set of Coddington smoothies, but they won't fit over my calipers due to the brake upgrade.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 10, 2005
#17
  • Apr 10, 2005
  • #17
Would rolling the fender lips help?
GDawg
1,469
Nevada
Apr 10, 2005
#18
  • Apr 10, 2005
  • #18
Yeah, roll your rear fenders.
R
rs-turbo
397
Orlando, Florida
Apr 11, 2005
#19
  • Apr 11, 2005
  • #19
What do you mean by rolling the fenders? Bending them underneath up? Might work, but not sure how this would be done and not really crazy about damaging the metal hoping it works. Won't this also weaken the fender a bit? While loaded for the show this past weekend I was parked on the grass. Went into a slight dip and needed to back up into my space, but the tire was flush against the fender and I couldn't move without grinding away the tire. Needed to unload the car first.
Was doing some more reading and the H&R 1 inch spacers have the hub support (hubcentric?). The ones I have center over the hub but have no center pieces for the rim to line up with, they are smooth. The bolts seem to have lined things up and I don't have any noticable vibration.
But wondering if the 1 inch H&R style is a better setup. Also noticed wear the other day on the inside passenger tire. I think this is more the alignment I got back in Dec, since it looks like it's been happening for a while, but I can't help wonder when I go back to the tire shop and they say it's due to the spacers. Probably best to take them off before going back.
Mike
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 11, 2005
#20
  • Apr 11, 2005
  • #20
That's exactly what it is. The best way to do it, would be to go to your local tool rental place (Autozone or whatever you guys have in the US) and rent the rolling tool and a heat gun. If you haven't access to the proper tool, an old school way is to use a baseball bat. Place the fat end of the bat between the tire and the edge of the fender and roll it along the tire on one end and over the edge of the fend lip with the other. Warm the surface of the fender lip up enough to soften the paint first, so it doesn't crack when you're performing the task. This act won't decrease the strength of your fenders noticeably, as you're not removing the lip, only reshaping it.
This is actually a Subaru in these pictures, but the principal is the same.
Here's another article that may explain it in better detail.....
http://www.eurotuner.com/howto/99762/index1.html
Mike
The wear on the edge of the tire is likely due to the spacers rubbing against the fender, yes. But I doubt switch over to the H&R style likely isn't going to make any difference, unless you're able to see that the added .25" will make much of a difference. Also, the reason yours do not align with the hub of the wheel is because they are not hub centric, but in fact lug centric. One is really no better than the other unless you've got issues with the rim being out of balance.
1 of 2 Next Last
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
