Mach 1 wheel spacers ???
I tried some 1" spacers with the stock wheels on the Mach. Click on My Garage and you can see the picture, the one with the Mach wheels is with the spacers. I used the M&M hub-centric style but in order to work with the Mach1 wheels you have to cut about 3/8" off the axle studs for them to work. This is because the stock studs stick out further than the 1" thickness of the spacers and there is not a recess for them to go into on the stock wheels.
Humm, you should be able to if you are logged in and clicking on My Garage below my avatar. Either way, here is a shot with the spacers on.
djlethalwang said:
Hey hotrodnut, what is that pic of in your garage thats under the hood? I see a Steeda logo on there...... what is it for?
Those are the Caster Camber plates used to get the front suspension geometry tweaked to perfection. Steeda calls them "7075 Aluminum 4-bolt Caster Camber Plates" part number 555-8095 and can be used on the 94-04 Mustangs according to their Catalog. :nice:
